Hi all, I'm hoping someone can help me a problem I can't figure out. Below is my code. I keep getting a RuntimeError: cannot open 'file I'm writing to' using a arcpy.da.InsertCursor. It keeps locking for some reason, I do not have arc open when running (running it from PyCharm), and it will write to the file thousands of times... I am writing line segments to a feature class and it will do it thousands of times, but then seemingly randomly say it can't access it. I have run it many times and it get's locked up in different places each time. The only info I can find is that people need to close their cursors, but all my cursors (both search and insert cursors) are closed after each use. I'm not sure what else to do. Any ideas? Description of what code is trying to do below if that is helpful at all as well as a screen shot of the error.
import arcpy
# Set environments / workspace. Workspace should point to a gdb that has all the effort point feature classes
arcpy.env.workspace = r"C:\Users\bhodge\Dropbox (New England Aquarium)\MonumentsWork\MonumentSpeciesDiversity\DataFromBob\DerivedData.gdb"
# This is the input points
fc = r"C:\Users\bhodge\Dropbox (New England Aquarium)\MonumentsWork\MonumentSpeciesDiversity\DataFromBob\DerivedData.gdb\EffortPoints_Prj_TEST_B"
# This is the output lines
sr = arcpy.Describe(fc).spatialReference
outputFC = arcpy.management.CreateFeatureclass(r"C:\Users\bhodge\Dropbox (New England Aquarium)\MonumentsWork\MonumentSpeciesDiversity\DataFromBob\DerivedData.gdb", "EffortLines_TEST", "POLYLINE", "", "DISABLED", "DISABLED", sr)
# Add desired fields to outputFC
arcpy.AddField_management(outputFC, "MONTH", "TEXT")
arcpy.AddField_management(outputFC, "YEAR", "SHORT")
arcpy.AddField_management(outputFC, "FILEID", "TEXT")
arcpy.AddField_management(outputFC, "EVENTNO", "LONG")
# Make a feature Layer of the input points to work off. This layer is temporary and will not persist after session ends unless saved
arcpy.MakeFeatureLayer_management(fc, "fc_lyr")
# Sort the table by fileid and eventno and create a new fc called fc_sort
sort_fields = [["FILEID", "ASCENDING"], ["EVENTNO", "ASCENDING"]]
fc_Sorted = arcpy.Sort_management("fc_lyr", "fc_sort", sort_fields)
# Create the search cursor
fields = ['FILEID', 'beauf_num', 'LEGTYPE', 'LEGSTAGE', 'vis_num', 'olviz_num', 'alt_num', 'LAND', 'MONTH', 'YEAR', "EVENTNO", "SHAPE@"]
with arcpy.da.SearchCursor(fc_Sorted, fields) as cur1:
for row in cur1:
# Name variables and assign values starting on first record of table
fileid1 = row[0]
beaufort = row[1]
legtype = row[2]
legstage = row[3]
visiblty = row[4]
oldvis = row[5]
alt = row[6]
land = row[7]
month = row[8]
year = row[9]
eventno = row[10]
# Get the geometry of the point for that record
geom1 = row[11].getPart()
# Go to the next row, get the fileid and geometry
next_row = cur1.next()
fileid2 = next_row[0]
land2 = next_row[7]
geom2 = next_row[11].getPart()
# Create an Array
array = arcpy.Array()
# Test the parameters to see if it should be on-effort
if ((fileid1 == fileid2) and (beaufort != None and beaufort <= 4) and ((visiblty != None and visiblty >= 2) or (oldvis == 1)) and \
(land != 1 and land2 != 1) and (alt != None and alt <= 366) and \
(not legtype == '0') and \
(not (legtype == '7' and legstage == ' ')) and \
(not (legtype == '9' and legstage == ' ')) and \
(not (legtype == '5' and legstage == ' '))):
array.add(geom1)
array.add(geom2)
polyline = arcpy.Polyline(array, sr)
with arcpy.da.InsertCursor(outputFC, ['SHAPE@', "MONTH", "YEAR", "FILEID", "EVENTNO"]) as insertCursor1:
insertCursor1.insertRow([polyline, month, year, fileid1, eventno])
del insertCursor1
array.removeAll()
else:
pass
del cur1
print("first with loop completed")
with arcpy.da.SearchCursor(fc_Sorted, fields) as cur2:
cur2.next()
for row in cur2:
fileid1 = row[0]
beaufort = row[1]
legtype = row[2]
legstage = row[3]
visiblty = row[4]
oldvis = row[5]
alt = row[6]
land = row[7]
month = row[8]
year = row[9]
eventno = row[10]
next_row = cur2.next()
land2 = next_row[7]
# Create an Array
array.add(geom1)
array.add(geom2)
with arcpy.da.InsertCursor(outputFC, ['SHAPE@', "MONTH", "YEAR", "FILEID", "EVENTNO"]) as insertCursor2:
insertCursor2.insertRow([polyline, month, year, fileid1, eventno])
del insertCursor2
array.removeAll()
else:
pass
del cur2
print("Done")
This is the Error I get, but this changes depending on the run. Sometimes it's in in insertCursor1 sometimes in insertCursor2 depending on how far it get's that run.
"C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe" "C:/Users/bhodge/Dropbox (New England Aquarium)/MonumentsWork/MonumentSpeciesDiversity/MonumentsPython/Trackline_Fields.py"
File "C:/Users/bhodge/Dropbox (New England Aquarium)/MonumentsWork/MonumentSpeciesDiversity/MonumentsPython/Trackline_Fields.py", line 59, in <module>
RuntimeError: cannot open 'C:\Users\bhodge\Dropbox (New England Aquarium)\MonumentsWork\MonumentSpeciesDiversity\DataFromBob\DerivedData.gdb\EffortLines_TEST'
Process finished with exit code 1
Code description: Basically I'm running through a point table, looking at variables in the first row, and some in the next row and if those parameters meet my requirements, I draw a line to connect the points and save that to a featureclass I created along with some variables I need attached to those line segments. I run through two searchCursors because of how I need to access the first and second line, it skips one iteration, (basically the first one compares points 1&2, 3&4, etc.) so I run it through a second searchCursor accessing the opposites (comparing 2&3, 4&5, etc.). It's somehow locking the file I'm trying to write to in the insertCursor, but it does so randomly and I don't know why or how to fix it. Thanks in advance for any suggestions!
