Cannot delete temp gdb on subsequent iterations because of lock
2660
01-14-2021 07:50 AM
FranklinAlexander
I am having a major problem preventing me from running a python 3x script. I am iterating over dozens of folders and creating lots of temporary data on each iteration. I am creating a temp gdb to store the temp data, then deleting and creating a new one on each pass. I have done this before with no issue, but now, after the first iteration I am getting a lock error Cannot delete C:/WebDev/Projects/...\temp.gdb. May be locked by another application. I want to emphasize that nothing is open, all programs including ArcPro have been closed before running the script and the error persists. I know this is a common issue and am hoping that someone can please give me a work-around. I have also tried just overwriting the gdb, but cannot do that either.
I have found this statement in the esri documentation regarding schema locks:
"Scripts may always update the schema of data created by tools within the same script, even if the current workspace is being used by another application."
If I understand this correctly, as long as the data being created from within the script (including the temp gdb) I should not be getting a lock error when attempting the delete it.
Can anyone please shed some light on this?
Thanks!
Tags (3)
FranklinAlexander
Yes, I did try that and it works great once I have finished developing and testing the script:
tempDB = arcpy.env.scratchGDB
While testing, however, I need to be able to see the temp data so I can troubleshoot my errors and I cannot do that if the temp data is in memory. I did find a solution that seems to be working so far. I just create a fresh temp gdb first (not inside the for loop) and set arcpy.env.overwriteOutput = true. I don't have any lock errors deleting the temp gdb when on the 1st iteration, so that works fine. Just a little frustrating that I have been testing this script for weeks without any issue (even with ArcPro open!) and the last few days I started getting the lock error.
Thanks for the suggestion and it's nice to have that option when setting the script to run on a schedule from the enterprise server. Less that can break!
DanPatterson
MVP Esteemed Contributor
is in_memory not an option?
Write geoprocessing output to memory—ArcGIS Pro | Documentation
... sort of retired...
FranklinAlexander
JoshuaBixby
With nothing open that access that FGDB, make sure there are no orphaned lock files.  If a previous run terminated prematurely or incorrectly, it might be an orphan lock that the script is seeing and not allowing the FGDB to be cleaned up.
FranklinAlexander
Thanks for the suggestion. I am not sure I am able to check on that since I don't have admin privileges. However, I don't think that is the issue since the script doesn't throw an error on the first iteration. If there is an orphan lock, then I think it is being caused by some process in the script and not by ArcPro or some other program not releasing it. At this point, I have found a workaround, so it's not an issue any more.
