Can't Install setuptools 0.9.7
2397
07-26-2013 10:14 AM
PaulHuffman
I'm stumped by my inability to install setuptools 0.9.7 on Windows 7,64, python 2.7.2. On running ez_setup.py I got the error:
Downloading https://pypi.python.org/packages/source/s/setuptools/setuptools-0.9.7.tar.gz Extracting in c:\users\paul\appdata\local\temp\tmptm3fqf Now working in c:\users\paul\appdata\local\temp\tmptm3fqf\setuptools-0.9.7 Installing Setuptools Something went wrong during the installation. See the error message above.  Traceback (most recent call last):   File "C:\Users\Paul\Documents\pyscripts\ez_setup.py", line 264, in <module>     sys.exit(main()) SystemExit: 2
Because python is installed down in c:\python27\arcgis10.1, I thought I'd try adding an environmental variable %PYTHON_PATH% and append it to %PATH%, but I got the same messages as above. But at least I can start python from any folder now.
Could it be that the python that ArcGIS installs is 32 bit, but the version of setuptools I downloaded is 64 bit, that somehow the download site sensed my OS?
PaulHuffman
ez_setup.py would not install setuptools-0.9.8 for me either. I didn't spot anything in the script that sensed my OS and downloaded the 64 bit version.
But I downloaded setuptools.-0.9.8.tar.gz from https://pypi.python.org/packages/source/s/setuptools, unpacked it myself, opened cmd and changed directory to the unpacked folder, ran "python setup.py install" and everything installed without a problem.
JasonScheirer
Esri Alum
You may need to run as administrator, maybe it can't write into those Python install folders as your current user.
PaulHuffman
You mean IDLE, running under my administrator account, isn't running with admin rights?
PaulHuffman
NateArnold
Paul,
Thanks for posting your solution - I needed pip and poster, which required setuptools.  Your workaround helped me get everything working.
Nate
