Can someone please write a code for me created a Projected UTM Grid over a sphere of the earth?
9786
13
04-26-2016 08:07 AM
TylerKloesel
Hello! I am in desperate need of a code to be written for me. I honestly have no idea what to do or even where to begin. IF anyone is willing and able to write it for me, I would greatly appreciate it. Assignment 14.1 task 2.
Thank you!
Tags (1)
AdrianWelsh
MVP Honored Contributor
Howdy Tyler,
From your Word doc, I do not even see a 14.1. I am guessing this is for a class and is due really soon?
It might be easier for you to write out what you need in the forum box.
TylerKloesel
Hello,
The screen shots are actually the assignment, I forgot that  I cut off the Assignment 14.1 portion of it.
But this is the assignment.
TylerKloesel
Do you thank that you can do it?
DarrenWiens2
What have you got so far? What have you tried and what isn't working? You need to do some of it.
TylerKloesel
I don't have anything because I have no idea where to even start. I was out yesterday because I was at a conference.
AdrianWelsh
Has your class used Python before? Has your instructor gone over how to begin with this? Does your instructor have office hours or a way to contact them for assistance?
DarrenWiens2
Without you even trying, it's hard to help. Your assignment lays out the instructions.
Here's a link with an example of creating a polygon. Good luck!
AdrianWelsh
To simplify Darren's link, here is the code sample on creating a polygon:
import arcpy
# A list of features and coordinate pairs
feature_info = [[[1, 2], [2, 4], [3, 7]],
                [[6, 8], [5, 7], [7, 2], [9, 5]]]
# A list that will hold each of the Polygon objects
features = []
for feature in feature_info:
    # Create a Polygon object based on the array of points
    # Append to the list of Polygon objects
    features.append(
        arcpy.Polygon(
            arcpy.Array([arcpy.Point(*coords) for coords in feature])))
# Persist a copy of the Polyline objects using CopyFeatures
arcpy.CopyFeatures_management(features, "c:/geometry/polygons.shp")
