Can I create a Mobile Map Package with metadata using ArcPy?
1359
10-06-2023 01:25 PM
JBuchanan
I was attempting to figure out why my metadata does not seem to carry over when I packed my layers as a mobile map package(.mmpk). When I check my package with python using the arcpy.da.Describe() method it returns a bunch of values pertaining to my map package and the one that caught my eye was "metadataRetrieved" which was set to False. I don't see anywhere where I can tell ArcPro to keep the layer's metadata.
Is there a way I can create the mmpk through python and manually set that metadataRetrieved value to True? Does this value even have anything to do with the layer's metadata?
Any advice on creating a Mobile Map Package with metadata would be greatly appreciated.
DanPatterson
MVP Esteemed Contributor
Check what you can specify here
Create Mobile Map Package (Data Management)—ArcGIS Pro | Documentation
in the code example section
... sort of retired...
