Calling arcpy.env.overwriteOutput
4782
03-16-2012 09:00 AM
JohanSmith
How do I go about calling the arcpy.env.overwriteOutput function?
i.e. [ATTACH=CONFIG]12779[/ATTACH]
The print statement clearly shows that it is 'True' but my if else statment is not calling it in the same manner.
J
JasonScheirer
Esri Alum
== True
, not
== 'True'
, the quotes matter
curtvprice
The quotes matter
The reason the quotes matter is arcpy.env.overwriteOutput is a boolean value, not text, no matter how you set it.
>>> arcpy.env.overwriteOutput = 'True'
True
>>> arcpy.env.overwriteOutput = 1
True
Fortunately for you, it seems, Esri has set things up so if you set it this property to  'False' (string) it evaluates to False. (Normally in Python, any non-null string evalulates to boolean True.)
>>> arcpy.env.overwriteOutput = 'False'
False
>>> bool('False')
True
Also since it is boolean type your original test can be written more simply:
if arcpy.env.overwriteOutput:
  print "It is true!"
else:
  print "It is false!"
