calculating polyline length in polygons
1044
02-22-2011 11:39 AM
davidwelch
I am trying to calculate line length in polygons.
the polygon file is large ~50,000, the polyline file are roads.
with smaller file sizes I used arcgis 'intersect' and then did tabular analysis.
the file size created by doing intersection is going to be too big to handle with this approach.
any suggestions?
KimOllivier
Honored Contributor
50K polygons? Surely not too large, I regularly run intersects with much larger numbers, 100 times larger. If it is too large then partition the dataset into smaller sets with a selection or definition first and combine the results. At 10.0 I understood that the partitioning is automatic.
davidwelch
perhaps the file will be manageable, however, I started the process on the 50,000 k file and it ran for about 5 hours today. .. still not finished.
I did a test with 34 polygons and the resulting file was 5000 records.
at this rate the file on my 50,000 k file will have more than a million records.
a program that could intersect then tabulate each record would work.
unfortunately, I have trouble programming myself out of a box... let alone doing something useful.
thanks
KimOllivier
Honored Contributor
I agree 5 hours is far too long.  I have a rule of thumb that states "If a single process takes longer than a cup of coffee, then interrupt it and find a better way". I will not be able to produce benchmarks with times longer that a cup of coffee, life is too short.
I now remember my recent 'better way' was to use a Workstation intersect which only took a few minutes, I have to admit that an ArcGIS intersect failed first on the same data and since I have a better way I was quick to take that rather than research the issue. I was already using a file geodatabase that is indexed and cleaned. It was already on a local high speed disk drive. It failed quickly.
The idea of looping through the features using a script seems likely to take a very long time because of the overhead of starting an intersect process for each likely polygon/polyline combination. You would have to search to find which combinations to compare and this needs a spatial index to be efficient but even then it would be slow. Python is supposed to be a 'glue' of fast optimised tools, not the tool itself. So, alternative tools seem the best course.
I have tried another intersect in ArcGIS 10.0 SP1 on an Acer laptop with Windows 7, i5 Intel 4 core processor, 4GB of memory
Polygons 42,496, polylines 221,896, tolerance 1 metre, time 5min 43sec.  Nothing wrong with that.
So to your data not performing. Clean the layer, maybe generalize a little for the purpose of the overlay. Are they both in a local projection? In a local file geodatabase? Get out of SDE. On a local disk? Output to a local file geodatabase. Strip off unnecessary fields. Is your scratch workspace a file geodatabase (not just a folder)? Do you have any unusually large features? Split them up. Multi-parts are not good for geoprocessing, split into singleparts.
