Calculating median in grouped data using ArcMap
18482
53
01-31-2020 10:46 AM
RafaelMichael
I got stuck when calculating the median age in grouped data (age ranges) for each feature (each feature is a single administrative unit). I have about 18,000 features.
Field names indicate age ranges: 0-14, 15-64, 65-100. In the "median" field I would like to calculate the median age for each feature. I found a website https://atozmath.com/StatsG.aspx?q=1 where you can calculate such a median for a single feature, for example the first feature from the attribute table above.
The page easily calculated the median for the first feature in the image, and the page also wrote how it calculated it, but I don't know how to write a universal script for a "median" field to calculate the median for each feature.
RafaelMichael
now there is an error with this file path
RafaelMichael
how to write it so that was good?
DavidPike
MVP Notable Contributor
I've edited the original code to account for my stupidity.
Also you need to specify you path with 'r' then in quotes as per the code.
E.g.         r'c:/users/david/project.gdb'
RafaelMichael
DavidPike
Have you done as I said mate?
RafaelMichael
my path looks like this and still error
DavidPike
Can you export your shapefile to a feature class? Not sure what's wrong.
RafaelMichael
DavidPike
Haha, I've edited the original to count it as a list rather than new parameters. My bad.
RafaelMichael
