Calculating geometry using pyscripting: failed to read polygon input feature
9177
20
10-03-2016 08:33 PM
GoldenJiang
I'm following an ESRI online learning tutorial: Creating Python Toolboxes Using ArcGIS 10.1.
I copy the script and test on my data but the new tool only recognises 'Street' as an input feature.
Can anyone tell me where is wrong with the codes below?
import arcpy
class Toolbox(object):
 def __init__(self):
 """Define the toolbox (the name of the toolbox is the name of the
 .pyt file)."""
 self.label = "Calculate Geometry"
 self.alias = "geometry"
# List of tool classes associated with this toolbox
 self.tools = [CalculateGeometry]
class CalculateGeometry(object):
 def __init__(self):
 """Define the tool (tool name is the name of the class)."""
 self.label = "CalculateGeometry"
 self.description = ""
 self.canRunInBackground = True
def getParameterInfo(self):
# first parameter
 """Define parameter definitions"""
 in_features = arcpy.Parameter(
 displayName = 'Input Feature',
 name = 'in_features',
 datatype = 'Feature Layer',
 parameterType = 'Required',
 direction = 'Input')
 in_features.filter.list = ['Point','Polyline','Polygon']
# second parameter
 field = arcpy.Parameter(
 displayName = 'Field name',
 name = 'field_name',
 datatype = 'Field',
field.parameterDependencies = [in_features.name]
 # only show field belongs to the input feature
 in_features.filter.list = ['Short','Long','Double','Float','Text']
# third parameter
 geomProperty = arcpy.Parameter(
 displayName = 'Property',
 name = 'geomProperty',
 datatype = 'String',
# fourth parameter
 units = arcpy.Parameter(
 displayName = 'Units',
 name = 'units',
 parameterType = 'optional',
 direction = 'Input',
 enabled = False)
# fifth parameter
 out_features = arcpy.Parameter(
 displayName = 'Output Features',
 name = 'out_features',
 parameterType = 'Derived',
 direction = 'Output')
 out_features.schema.clone = True
params = [in_features, field, geomProperty, units, out_features]
 return params
 def isLicensed(self):
 """Set whether tool is licensed to execute."""
 return True
def updateParameters(self, parameters):
 """Modify the values and properties of parameters before internal
 validation is performed. This method is called whenever a parameter
 has been changed."""
# Get Inputs
 in_features = parameters[0]
 geomProperty = parameters[2]
 units = parameters[3]
# Geometry Property Filter Lists
 pointPropertyList = ['X Coordinate of Point',
 'Y Coordinate of Point']
 linePropertyList = ['Length', 'X Coordinate of Line Start',
 'Y Coordinate of Line Start',
 'X Coordinate of Line End',
 'Y Coordinate of Line End']
 polygonPropertyList = ['Area','Perimeter',
 'X Coordinate of Centroid',
 'Y Coordinate of Centroid']
# Get shape type of input to determine
 # filter list for geometry property parameter
if in_features.value:
    desc = arcpy.Describe(in_features.valueAsText)
    if desc.shapeType == 'Point':
       geomProperty.filter.list = pointPropertyList
    elif desc.shapeType == 'Polyline':
       geomProperty.filter.list = linePropertyList
    elif desc.shapeType == 'Polygon':
       geomProperty.filter.list = polygonPropertyList
# Unit Filter Lists
 areaUnitList = ['Acres','Ares','Hectares','Square Centimeters','Square Inches','Square Feet','Square Kilometers','Square Meters','Square Miles','Square Millimeters','Square Yard','Square Decimeters']
 lengthUnitList = ['Centimeters','Feet','Inches','Kilometers','Meters','Miles','Millimeters','Nautical Miles','Yards','Decimal Degrees']
# Get geometry property input to determine filter list for unit parameter
 if geomProperty.value:
    if geomProperty.valueAsText == 'Area':
       units.enabled = True
       units.filter.list = areaUnitList
    elif geomProperty.valueAsText in ['Length','Perimeter']:
       units.enabled =True
       units.filter.list = lengthUnitList
    else:
       units.value = ''
       units.filter.list = []
       units.enabled = False
    return
 def updateMessages(self, parameters):
 """Modify the messages created by internal validation for each tool
 parameter. This method is called after internal validation."""
 geomProperty= parameters[2]
# Check is input is Multipoint or Multipatch and if so set an error
    if desc.shapeType in ['Multipoint','Multipatch']:
      in_features.setErrorMessage('{0} features are not supported.'.format(desc.shapeType))
# Check if certain geometry property value is set with no units and add error
 if geomProperty.valueAsText in ['Length','Perimeter','Area']:
    if not units.value:
       units.setErrorMessage('Units required for {0} property'.format(geomProperty.valueAsText))
 return
 def execute(self, parameters, messages):
 """The source code of the tool."""
 # Get Input
 in_features = parameters[0].valueAsText
 field = parameters[1].valueAsText
 geomProperty= parameters[2].valueAsText
 units = parameters[3].valueAsText
shapeFieldName = arcpy.Describe(in_features).shapeFieldName
# Create the expression
 exp = '!' + shapeFieldName
 if geomProperty == 'Area':
    exp += '.area@'+ units.replace('','')
 elif geomProperty in ['Length','Perimeter']:
    exp += '.length@'+ units.replace('','')
 else:
    propertyList = geomProperty.split('')
    coord = propertyList[0]
    if propertyList[-1] in ['Point','Start']:
       exp += '.firstPoint.' + coord
    elif propertyList[-1] == 'End':
       exp += '.lastPoint.'+ coord
    elif propertyList[-1] == 'Centroid':
       exp += '.centroid.'+ coord
exp+= '!'
messages.addMessage(
 '\nExpression used for field calculation: {0}\n'.format(exp))
#Calculate Field
 arcpy.CalculateField_management(in_features,field,exp,'PYTHON_9.3')
return‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RandyBurton
I don't believe it relates to the environment.  The tool is able to list layers in a map and allows navigation to geodatabases and shape files.
