Calculating a destination point based on an origin, distance and bearing?
5207
9
04-25-2022 01:36 PM
EricEagle
I'm porting a tool from R to be run in a managed ArcGIS Pro instance (no access to R).  In the script, destination points are calculated from a known origin based on bearing and distance.
The script relies on the geosphere destPoint() method to do it, and is invoked like this:
x = destPoint(origin, bearing, distance)
x is a location object with .latitude and .longitude properties that return as floats for use in further processing.
This seems like a super straightforward geometric problem but I am struggling to find how to use ArcPy to accomplish it.  For initial testing purposes I gave up and just pip installed GeoPy, using geopy.distance.distance(unit=distance).destination((origin.Y, origin.X), bearing) and it works beautifully but I do not like delivering stuff with janky 3rd party dependencies.
How do I do this in ArcPy without re-writing half of GeoPy?
DanPatterson
MVP Esteemed Contributor
import arcpy
pnt = arcpy.Point(300000, 5000000)
SR = "NAD 1983 CSRS MTM  9"
p_geom = arcpy.PointGeometry(pnt, spatial_reference=SR)
# -- make a new p_geom at 45 degrees from N at 1000m
new_p = p_geom.pointFromAngleAndDistance(angle=45.0, distance=1000, method='GEODESIC')
new_p[0]
 <Point (300707.56992333446, 5000706.502158922, #, #)>
# --- lots more
dir(new_p)
['JSON', 'WKB', 'WKT', '__add__', '__class__', '__cmp__', '__delattr__',
  '__dict__', '__dir__', '__doc__', '__eq__', '__format__',
...snip
 'angleAndDistanceTo', 'area', 'boundary', 'buffer', 'centroid', 'clip',
 'contains', 'convexHull', 'crosses', 'cut', 'densify', 'difference',
 'disjoint', 'distanceTo', 'equals', 'extent', 'firstPoint', 'generalize',
 'getArea', 'getGeohash', 'getLength', 'getPart', 'hasCurves',
 'hullRectangle', 'intersect', 'isMultipart', 'labelPoint', 'lastPoint',
 'length', 'length3D', 'measureOnLine', 'overlaps', 'partCount',
 'pointCount', 'pointFromAngleAndDistance', 'positionAlongLine', 'projectAs',
 'queryPointAndDistance', 'segmentAlongLine', 'snapToLine',
 'spatialReference', 'symmetricDifference', 'toCoordString', 'touches',
 'trueCentroid', 'type', 'union', 'within']
... sort of retired...
by Anonymous User
Not applicable
You might try the Bearing Distance to Line tool.
How do you know GeoPy is janky? Did you test it against your R tool and get different results?
Another great option is to use geographiclib.
EricEagle
Sorry!  I don’t mean GeoPy is janky only the dependency management inside a Python toolbox for ArcGIS Pro is janky with any third party dependency.
I’d like to avoid the Bearing Distance to Line tool because it is IO bound (needs output to disk) and I don’t need lines and all the overhead, just points derived within memory space.
by Anonymous User
Not applicable
No apologies needed - It's always worth testing and reporting problems or discontinuity between different solutions. Totally understand the need for tool and environment portability.
It looks like Dan's solution is what you're looking for. For posterity it's worth nothing you should be able to write the Bearing Distance to Line output to memory.
https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/basics/the-in-memory-workspace....
EricEagle
Thanks!  I’ll investigate that more.
JamesHood
From a point feature class as input:
import arcpy
# samplept is a point feature class with xcoord, ycoord fields as double, calculated geometry to wgs84,
#also added dist field, and bearing fields both as double, both field calculated with the distance and bearing values.
input_table = r"C:\Data\Points\points_data.gdb\samplept"
output_line = r"C:\Data\Points\points_data.gdb\bearingLine"
# BearingDistanceToLine
#https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/bearing-distance-to-line.htm
arcpy.BearingDistanceToLine_management(input_table, output_line, 'xcoord', 'ycoord', 'dist',
                                       'KILOMETERS', 'bearing', 'DEGREES','GEODESIC')
#Feature-vertices-to-points.htm
#https://pro.arcgis.com/en/pro-app/2.8/tool-reference/data-management/feature-vertices-to-points.htm
out_point = r"C:\Data\Points\points_data.gdb\bearingPoints"
arcpy.management.FeatureVerticesToPoints(output_line, out_point, "END")
output  is point feature class also.
EricEagle
This is great but I’d like to do it in memory like with GeoPy without incurring overhead of writing feature classes to disk.
JamesHood
Just for reference I modified my approach to no longer output  intermediates to hard disk.
import arcpy
output_line = r"in_memory\bearingLine"
out_point = r"in_memory\bearingPoints"
DanPatterson
import arcpy
new_p[0]
# --- lots more
dir(new_p)
...snip
EricEagle
Nice!  This looks way closer to what I’m looking for.  Will give it a shot and report back, thanks Dan
