CalculateField with PYTHON with international settings
5026
6
04-22-2011 03:32 AM
CoDrost
I tried to calculate an area with:
  gp.CalculateField(fcGFE_Result,'AREA','!SHAPE.AREA!','PYTHON')
When I use the internation settings with a . as decimal separator everything is doing just fine.
But my localsettings are set to ((Dutch_Netherlands)) with a "," as a decimal separator.
The error message I got is:
arcgisscripting.ExecuteError: ERROR 000539: Error running expression: 304852,037832481 <type 'exceptions.SyntaxError'>: invalid token (<string>, line 1)
When I using the same command within ArcMap I got no problem.
I also tried to set the locale parameters:
  locale.setlocale(locale.LC_ALL, 'C')
and
locale.setlocale(locale.LC_ALL, '')
Is there anybody with a proper solution? Now I am using a workarround, but I am still curious....
JasonScheirer
Esri Alum
CoDrost
Use locale.atof.
I tried already the locale option:
  gp.calculatefield(fn,'area','locale.atof(!shape.area!)','PYTHON')
gives Error:
  ExecuteError("ERROR 000539: Error running expression: locale.atof(7133,63322549874) <type 'exceptions.AttributeError'>: 'int' object has no attribute 'replace'\nFailed to execute (CalculateField).\n
JasonScheirer
Esri Alum
gp.calculatefield(fn,'area','locale.atof("!shape.area!")','PYTHON')
CoDrost
Thanks, it works!!!
Isn't it posible to disable the international settings when programming with ArcGIS in Python? It is very confusing when ArcMap functionate well with the same command and in a script you need to "locale" the geoprocessing commands...
JasonScheirer
Esri Alum
Unfortunately due to implementation details, Python doesn't see the ArcMap locale, meaning you essentially have to double-set it, once in ArcGIS and then once again in your Python script.
DanPatterson_Retired
Is this double-setting being addressed in some release?  It also occurs when using SA tools necessitating that one set environments in any running tools rather than relying on defaults set elsewhere.
