CalculateField_management
5829
15
07-12-2021 02:03 AM
danielROUFFART1
Hi everybody,
i need some help about the arcpy expression CalculateField_management.
So wrote a py program to correct some field in a layer.
so wrote my py prog like this
import arcpy
# Recherche de la gdb pour correction
ma_table = R"C:\représentation parcelaire\cadpmm_vierge.gdb"
# rappatriment des champs utilises dans la fonction
expression = "ma_fonction(param_ccogrm=!ccogrm!, param_ddenom=!ddenom!)"
print("environnement charge")
# correction du champ ccogrm
code_block: str = """def ma_fonction(param_ccogrm, param_ddenom):
if param_ccogrm == 1 and ddenom == "COPROPRIETAIRES DU LOTISSEMENT LE COTEAU":
return 7
return None"""
arcpy.CalculateField_management(
in_table=ma_table,
field="ccogrm",
expression=expression,
expression_type="PYTHON3",
code_block=code_block
so when i execute the program, i've got an error message
File "C:/Users/d.rouffart/PycharmProjects/pythonProject/2021_07_08_ReplaceValue.py", line 60, in <module>
can you help me to resolve my problem please. I don't see xhere is the problem .
thanks
HamishMorton
Hi @danielROUFFART1,
You havent specified your table in the line - it is just the path to the geodatabase:
ma_table = r"C:\représentation parcelaire\cadpmm_vierge.gdb"
does it work if you specify the table name?
ma_table = r"C:\représentation parcelaire\cadpmm_vierge.gdb\ma_table"
The formatting of the function also looks a bit strange where you have pasted it to the browser. Might it be safer to use the following?
code_block = """
      return 7
   else:
      return None
Hamish
DanPatterson
MVP Esteemed Contributor
code_block ="""
    if (param_ccogrm == 1) and (ddenom == "COPROPRIETAIRES DU LOTISSEMENT LE COTEAU"):
       return 7
    return None
don't put str = in the code block if you did
... sort of retired...
danielROUFFART1
thanks for your help,
so i've retired the str in the prog and i've got the same message.
HamishMorton
code_block = """
      return 7
   else:
      return None
Hamish
danielROUFFART1
hi HamishMorton
so i try your solution and i've got thie reponse for
# coding: utf-8
import arcpy
ma_table = r"C:\représentation parcelaire\cadpmm_vierge.gdb\proprio"
code_block ="""
return 7
else:
return None
in_table=ma_table,
field="ccogrm",
print("CalculateField ok")
and for response:
"C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe" C:/Users/d.rouffart/PycharmProjects/pythonProject/2021_07_08_ReplaceValue.py
File "C:/Users/d.rouffart/PycharmProjects/pythonProject/2021_07_08_ReplaceValue.py", line 27, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 5209, in CalculateField
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 5206, in CalculateField
retval = convertArcObjectToPythonObject(gp.CalculateField_management(*gp_fixargs((in_table, field, expression, expression_type, code_block, field_type), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 511, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 160706: Cannot acquire a lock.
Échec de l’exécution de (CalculateField).
HamishMorton
Okay thats a bit better. Is the feature class open or being edited in any other app? If so try closing those and then run the script again from wherever you are running it. e.g. your IDE.
Hamish
danielROUFFART1
so i close arcgis pro and i try to start my py with charmPy and i've got that
File "C:/Users/d.rouffart/PycharmProjects/pythonProject/2021_07_08_ReplaceValue.py", line 21, in <module>
raise e
arcgisscripting.ExecuteError: Échec de l’exécution. Les paramètres ne sont pas valides.
ERROR 000732: Table en entrée: Dataset C:\représentation parcelaire\cadpmm_vierge.gdb\proprio does not exist or is not supported
Process finished with exit code 1
HamishMorton
That is odd. I would make sure that your data still exists and that it is a feature class or table.
import arcpy
path = r"C:\représentation parcelaire\cadpmm_vierge.gdb\proprio"
if arcpy.Exists(path):
  print("{} exists".format(path))
  desc = arcpy.Describe(path)
  print("Data type is {}".format(desc.dataType))
else:
  print("{} does not exist".format(path))
Hamish
danielROUFFART1
Thanks for your help! thank of you i found the error!
i've forget an _ on the way to the gdb.
so now i've got that
"C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe" C:/Users/d.rouffart/AppData/Roaming/JetBrains/PyCharmCE2021.1/scratches/scratch.py
CalculateField ok
Process finished with exit code 0
one more time thanks for your help
DanPatterson
so it looks like this now?
import arcpy
expression = "ma_fonction(!ccogrm!, !ddenom!)"
code_block = """
        return 7
    return None
    in_table=ma_table,
    field="ccogrm",
