CalculateField_management. NameError: name is not defined
10567
20
05-11-2017 08:15 PM
MichaelTinker
Why am I getting a NameError here?
Here is the basic python:
table = r'D:\output.gdb\table'
m = 0.01
arcpy.CalculateField_management(table, 'FIELD_B', '!FIELD_A! * m', 'PYTHON')
The error states: NameError: name 'm' is not defined
How is this so, as I have just defined m right above?
Thanks much for your help!
Best regards, Mike
MichaelTinker
No, it doesn't. However, it is a parameter input by the user.
DanPatterson_Retired
Then you need to show the show the script where the parameter is getting passed.  And it is probably a string parameter, so check to see if you need to 'float' it
curtvprice
No need to float it, a parameter "{}".format("0.1") is the same as "{}".format(0.1). The tricky part is to get your user-input variable into the string m.
.... show the show the script where the parameter is getting passed .... my comment
This is the part that is missing... getparameterastext? getparameter? if it was just 0.01, then everything should work as designed
MichaelTinker
Gentlemen, thanks for your feedback. Been offline couple of days.
Here are the relevant lines of the "real" script in question
slope = arcpy.GetParameterAsText(2)
m = float(slope)
arcpy.CalculateField_management(NHDFlowline,'THRESHOLD', '!MEAN! * m', 'PYTHON')
Where NHDFlowline is an existing table in an output gdb (set as the working environment). A couple fields I have added to this table are THRESHOLD and MEAN.
I am attempting to field calculate THRESHOLD by multiplying (MEAN * m) where m is the slope of a regression line.
curtvprice
This error means you got your parameters out of order. Joshua's first example should work well if you can figure out how to plug in your workflow. Feel free to post a code snippet (formatted, please): https://community.esri.com/people/curtvprice/blog/2014/09/25/posting-code-blocks-in-the-new-geonet?s...
Here are 4 examples using one of my calculations...
#  formatting the expression
m = 0.1
expr = "!POINT_Y! * {}".format(m)
expr   # yields
'!POINT_Y! * 0.1'
# putting the 0.1 within the expression
arcpy.CalculateField_management(in_table="fishnet_label",
                                field="test",
                                expression="!POINT_Y! * 0.1",
                                expression_type="PYTHON_9.3",
                                code_block="")
# put the expression in from above
                                field="test",
                                expression=expr,
                                code_block="")
# write a code block
codeblk ='m =  0.1\nglobal m\ndef test(fld):\n    return fld * m')
                                field="test",
                                expression="test(!POINT_Y!)",
                                code_block=codeblk)
Something has to work
MichaelTinker
Thanks for sticking with the thread Dan. I'll go through examples.
NHDFlowline = 'D:\Generalizer\output.gdb\NHDFlowline_0202'
HUC = 'D:\Generalizer\output.gdb\huc12_mn_ppt_0202'
arcpy.CalculateField_management(NHDFlowline,'THRESHOLD','!MEAN! * .01', 'PYTHON')
This first one works. However, m is supposed to be an input parameter so...
m = input("enter m")
arcpy.CalculateField_management(NHDFlowline,'THRESHOLD','!MEAN! * m', 'PYTHON')
This is the usual error I get, which is: NameError: name 'm' is not defined.
Ok, lets use your first example:
expr = '!MEAN!' * {}.format(m)
arcpy.CalculateField_management(NHDFlowline,'THRESHOLD','expr', 'PYTHON')
Now the error says:
AttributeError: 'dict' object has no attribute 'format'
It thinks that !MEAN! is a dictionary object...
arcpy.CalculateField_management(in_table=NHDFlowline,field='THRESHOLD',expression='expr',expression_type='PYTHON',code_block="")
This one has the same error: expr = '!MEAN!' * {}.format(m)
curtvprice
Code block #3 would have worked -- but you need a quote moved, and don't quote expr!  (It's a python variable of type str, not a string literal.)
expr = '!MEAN! * {}'.format(m)  # quote entire expression
# if m is .01, expr now is: "!MEAN! * .01"
arcpy.CalculateField_management(NHDFlowline, 'THRESHOLD', expr, 'PYTHON')‍‍‍‍‍‍‍‍‍‍‍
MichaelTinker
Thanks Curtis, that did it!
