CalculateField_management ERROR, I can't understand why
381
10-02-2017 04:03 AM
AlbertoOrpez_Milan
Hello friends,
I'm having troubles with CalculateField_management in a python script (arcpy). I'm getting this error:
arcgisscripting.ExecuteError: ERROR 000539: Invalid field ASCFxCC.CODVIA
This is my code:
GDBEntrada = "C:\data\mygdb"
arcpy.SelectData_management(GDBEntrada, "ASCFxCC")
expresion = 'funcion( !ASCFxCC.CODVIA!, !ASCFxCC.NUMPOL!, !ASCFxCC.DUPLICADO!)'
arcpy.CalculateField_management(AnnoCalle_Layer__2_, "Handle", expresion, "PYTHON_9.3", "def funcion (a,b,c):\\n  x='0'\\n  v='00000'\\n  n='0000'\\n  d=0\\n  if a != \"     \":\\n   v=a.lstrip('0')\\n   if b != '    ' :\\n     n=b.rstrip(' ')\\n     n=n.lstrip('0')\\n     if c != ' ':\\n       d= ord(c)\\n   x= v + n + str(d)\\n   return int (x)")
This is table ASFxCC in mygdb :
And this is the AnnoCalle_Layer__2_
Why I'm getting this ERROR ?
Thanks for your time,
Best,
Alberto.
LukeWebb
If you manually calculate the field inside arcmap, you can then copy as a python snippet the required code using the ArcGIS Results window.
Geoprocessing --> results
I guess you may need code like unless your data is joined:
expresion = 'funcion( !CODVIA!, !NUMPOL!, !DUPLICADO!)'
