Calculate mean in 8 day intervals for thousand of daily raster files using cell statistics
4980
13
11-19-2017 07:00 AM
LarryBiodun
Hi everyone, I have folder with thousands of average daily relative humidity raster files that I would like to use cell statistics to calculate the mean in 8 day intervals. The data has dates in the format YYYYMMDD. I've looked at a similar code written after a similar question was asked but it doesnt do the 8 day averaging. I've included the link to the other answered question and a picture of what the data look like. Your help is greatly appreciated.Calculate daily average of raster files based on their names in python xander_bakkersample data
XanderBakker
Esri Esteemed Contributor
It is good to hear that the files open correctly. In case the dates are consecutive and there will always be 8 elements for each calculation, I guess the chunk method mentioned in the thread referenced by Dan should work. I just ran this snippet:
def main():
    import os
    my_list = ["calc200601{0}.img".format("%02d" % (a,)) for a in range(1, 31)]
    out_ext = ".tif"
    for my_list_chunk in chunks(my_list, 8):
        first_name = my_list_chunk[0]
        name, ext = os.path.splitext(first_name)
        first_date = name[-8:]
        out_ras_name = "mean" + first_date + out_ext
        print out_ras_name, my_list_chunk
def chunks(l, n):
    """ Yield successive n-sized chunks from l."""
    for i in xrange(0, len(l), n):
        yield l[i:i+n]
if __name__ == '__main__':
    main()
Which yielded:
mean20060101.tif ['calc20060101.img', 'calc20060102.img', 'calc20060103.img', 'calc20060104.img', 'calc20060105.img', 'calc20060106.img', 'calc20060107.img', 'calc20060108.img']
mean20060109.tif ['calc20060109.img', 'calc20060110.img', 'calc20060111.img', 'calc20060112.img', 'calc20060113.img', 'calc20060114.img', 'calc20060115.img', 'calc20060116.img']
mean20060117.tif ['calc20060117.img', 'calc20060118.img', 'calc20060119.img', 'calc20060120.img', 'calc20060121.img', 'calc20060122.img', 'calc20060123.img', 'calc20060124.img']
mean20060125.tif ['calc20060125.img', 'calc20060126.img', 'calc20060127.img', 'calc20060128.img', 'calc20060129.img', 'calc20060130.img']
So, each chunk contains 8 rasters and the output raster takes the date of the first raster. In this case I added the .tif extension, but you could leave that extension off to create a Esri grid in a folder or point to an output fgdb.
To validate is this shell works, could you run the snippet below and see if this splits the list of raster up into the chunks you want?
def main():
    import arcpy
    import os
    # change this folder to the folder with the renamed img files
    input_folder = r'C:\GeoNet\Average8Days\output_files'
    out_ext = ".tif"
    arcpy.env.workspace = input_folder
    my_list = arcpy.ListRasters()
def chunks(l, n):
        yield l[i:i+n]
    main()
LarryBiodun
Hi Xander, works just like you said! However, as I really am a newbie to this scripting thing, I do not know where to insert the other code to run the actual cell statistics as I realise the above code just prints out the batches of 8 files. Could you please help that little bit further with where to insert the cell statistics code.
XanderBakker
Hi larry32 , can you try this code?
Change:
  • input folder with .img files on line 6
  • output folder or fgdb on line 9 and the corresponding extension on line 10
def main():
    import arcpy
    import os
    # define the output workspace and extension
    output_ws = r'C:\GeoNet\Average8Days\gdb\myFileGeoDB.gdb'
    out_ext = ""
    # create list of rasters in input workspace
    # checkout a Spatial Analyst license
    arcpy.CheckExtension("Spatial")
    # loop through chunks of 8 rasters
        # define the output name
        # now we have:
        # - an output raster filename
        # - the list of rasters for calculating the mean value
        # perform the cellstatistics with MEAN
        cellstat = arcpy.sa.CellStatistics(my_list_chunk, "MEAN", "DATA")
        # define file path of output raster and save cell statistics result
        outname = os.path.join(output_ws, out_ras_name)
        cellstat.save(outname)
def chunks(l, n):
        yield l[i:i+n]
    main()
LarryBiodun
Thanks Xander! Works like a dream. Very quick too.
Thanks Dan for the useful comments. I appreciate it all.
