Calculate length and width of polygons using Arcade in Expression Builder in the attribute table
1919
09-12-2021 07:40 AM
by Anonymous User
Not applicable
I am using attribute rules to automatically update cells in an attribute table. I need to auto-calculate the length and width of polygons (respectively) as the user creates them. Is there a way to do this using math/geometry functions in Arcade? It would work similarly to the tool Minimum Bounding Geometry that can calculate length and width of polygons.
I have no idea where to start, im new with scripting. Does expression builder use python or strictly arcade? Thank you in advance.
DavidPike
MVP Notable Contributor
what do you mean by length and width?
DanPatterson
MVP Esteemed Contributor
Getting this done as you enter the data is probably not a good idea since you really need
rectangle by width from
Minimum Bounding Geometry (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
