Calculate Field in ArcGIS Pro 2.7 Python Stand-Alone Fails
1864
01-06-2022 11:35 AM
GerryGabrisch
I am trying to execute a calculate field in arcpy from ArcGIS Pro 2.7.  Here is the relevant code.
#a confirmed existing shapefile ....
out_fc = r'C:\GIS\telemetrytags\individual_fish_individual_days\112_2019-04-12.shp'
# a confirmed and working add field....
arcpy.AddField_management(out_fc, 'TagID', "SHORT")
#The existing field name...
tagid = "TagID"
#The value to populate TagID with...in this case the value of tag is a float (with a value of 112.0) before I #convert it to an int and then string.
value = str(int(tag))
#code fails here with the message below.
arcpy.CalculateFields_management(out_fc, tagid, value, "PYTHON3")
Error Info:
Failed to execute. Parameters are not valid.
ERROR 000800: The value is not a member of Python 3 | Arcade.
ERROR 000728: Field 112 does not exist within table
Failed to execute (CalculateFields).
112 is the value I am trying to populate field TagID with and not the field name so I do not understand what is up with that error.
Another oddity - when I add my shapefile to ArcGIS pro and check the TagID field it returns that the field is a type Long with is not what I am doing with the calculate field.
Why is this 'the most simple of calculations' failing in arcpy for ArcGIS Pro 2.7
Luke_Pinner
MVP Regular Contributor
You're trying to use the syntax for Calculate Field with the Calculate Fields tool. The syntax for Calculate Fields is:
arcpy.CalculateFields_management(in_table, expression_type, fields, {code_block}, ...)
#Or
arcpy.management.CalculateFields(in_table, expression_type, fields, {code_block}, ...)
The syntax for Calculate Field is:
arcpy.management.CalculateField(in_table, field, expression, {expression_type}, {code_block}, etc...)
#Or
arcpy.CalculateField_management(in_table, field, expression, {expression_type}, {code_block}, etc...)
As you're only calculating a single field, just change to using the Calculate Field tool:
arcpy.CalculateField_management(out_fc, tagid, value, "PYTHON3")
#Or
arcpy.management.CalculateField(out_fc, tagid, value, "PYTHON3")
Luke_Pinner
#Or
#Or
#Or
