Calculate Field - Convert Meters to Feet
4687
03-27-2024 10:05 AM
kapalczynski
I am trying to calculate a field from the SHAPE.LEN field and convert it from meters to feet....
I ran the calculate field in ArcPro and it worked fine.. I exported the Python and it gave me this
import arcpy
arcpy.management.CalculateField("GIS_DATA.SDE_DITCHING", "LENGTH_FT", "MetersToFeet((float(!SHAPE.LEN!)))", "PYTHON3", """import math
def MetersToFeet(length):
    return (3.280839895) * length
""", "TEXT", "NO_ENFORCE_DOMAINS")
ANY THOUGHTS on why this is failing?
I now want to put this in a stand alone .py script that I will run with a bunch of other code... I did this and am getting this error... I tried all
import arcpy
layers_to_Update = {
"DitchingLayers": "Database Connections\\DEV@gis_data.sde\\GIS_DATA.SDE_DITCHING"
def updateLengthField():
    for layer in layers_to_Update.keys():
        fromSDE = layer
        updateLayer = layers_to_Update[layer]
        fieldUpdate = "LENGTH_FT"
        arcpy.env.workspace = "Database Connections\\DEV@gis_data.sde"
        arcpy.management.CalculateField(updateLayer, fieldUpdate, "MetersToFeet((float(!SHAPE.LEN!)))", "PYTHON3", """import math
if __name__ == '__main__':
    updateLengthField()
ERROR:
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000989: Python syntax error: File "<string>", line 2
IndentationError: unexpected indent
Failed to execute (CalculateField).
I then tried this and got this error
import arcpy
        fromSDE = layer
        print(updateLayer)
        print(fieldUpdate)
        arcpy.management.CalculateField("GIS_DATA.SDE_DITCHING", "LENGTH_FT", "MetersToFeet((float(!SHAPE.LEN!)))", "PYTHON3", """import math def MetersToFeet(length):return (3.280839895) * length""", "TEXT", "NO_ENFORCE_DOMAINS")
    updateLengthField()
ERROR:
ERROR 000989: Python syntax error: File "<string>", line 1
SyntaxError: invalid syntax
kapalczynski
got it... hunting and hunting finally looking at the network payload in the browser i saw the parameter was called calcExpression not expression or Update Expresstion in the image above... ... gotta love cryptic naming conventions ESRI puts out... parameter names are different for each method of updating... uggg
    url = urlCalculateFeatures
    whereclause='1=1'
    gis_payload = {
        'token': currenttoken,
        'f': 'json',
        'calcExpression':'[{"field": "LENGTH_FT", "sqlExpression": "Shape__Length*300.280839895"}]',
        'sqlFormat':'standard',
        'where': f'''{whereclause}'''
    print(gis_payload)
    response = requests.request("POST", url=urlCalculateFeatures, data=gis_payload)
kapalczynski
Never mind I got it with this
        fromSDE = layer
        arcpy.env.workspace = "Database Connections\\GIS_3_DEV@gis_data.sde"
        arcpy.management.CalculateField("GIS_DATA.SDE_VDOT_MAINT_DITCHING", "LENGTH_FT", "MetersToFeet((float(!SHAPE.LEN!)))", "PYTHON3", "", "TEXT", "NO_ENFORCE_DOMAINS")
kapalczynski
The above now works BUT I want to get this working against a REST service ...
So something like the below but not DELETE rather CACULATE
Any thoughts?
    url = urlDeleteFeatures
    whereclause='1=1'
    gis_payload = {
        'f': 'json',
    response = requests.request("POST", url=url, data=gis_payload)
    print("Done Deleting")
I am not sure how the expression would look
kapalczynski
Got with this:
BUT not sure how to get that into a python script..
Tried this... no error but nothing happening..
    whereclause='1=1'
    gis_payload = {
        'f': 'json',
        'url':'https://xxxx.xxx.xx.gov/env/rest/services/DEV/UpdateLengthField/FeatureServer/0',
        'expression':'[{"field": "LENGTH_FT", "sqlExpression": "Shape__Length*30.280839895"}]',
kapalczynski
    whereclause='1=1'
    gis_payload = {
        'f': 'json',
    print(gis_payload)
