Calculate field conditional statement using a date formula
11962
11
02-09-2016 10:25 PM
MoyaCalvert
Hi all,
I am using ArcGIS 10.3 to update a field with a numeric value that represents the elapsed time since the data was captured.  I can do this in a python script that I have attached to a model but I also want to be able to sometimes do it quickly from within ArcGIS desktop and I am stumped.
I have written a 3 step process:
1. Create an integer field then calculate the number of days since today (field name = ET):
In Field Calculator, ET =
(datetime.datetime.now() - arcpy.time.ParseDateTimeString(!ActivityDate!)).days
2.  Create a conditional Statement for "Elapsed Time" field as follows:
Expression:
Reclass(!ET!)
def Reclass(ET):
    if ( ET < 28):
        return 1
    elif ( ET>= 28 and ET < 91):
        return 2
    elif ( ET >= 91 and ET < 182):
        return 3
    elif ( ET >= 182 and ET < 365):
        return 4
    elif (ET >= 365):
        return 5
3. Delete the ET field
I really just want to declare a variable in my conditional statement for ET which would save having to create then delete the ET field, but everything I have tried does not work, for example:
Expression:
Reclass(ET)
ET = (datetime.datetime.now() - arcpy.time.ParseDateTimeString(!ActivityDate!)).days
def Reclass(ET):
    if ( ET < 28):
        return 1
etc etc
I cannot find any examples of conditional statements that use a variable instead of a field value in the Field Calculator, so any help would be appreciated.
DanPatterson_Retired
Moya ... et al...
For future reference
Using either numpy or the bisect module makes things much simpler when trying to do a sequential value reclassification ... whether it be text or numbers.  Some thoughts and brief tests, before put into functions.
dts = [1,28,29,91,92,182,183,365,366]
bins = [28,91,182,365,400]
#1
import numpy as np
c = np.digitize(dts, bins, right=True) + 1
result    list(c) = [1, 1, 2, 2, 3, 3, 4, 4, 5]
#2
import bisect
d = [ bisect.bisect_left(bins,i) + 1  for i in dts]
results  ditto
If these were put into a function they could do the reclassification for you.
In the examples here, a value of 1 was added to the returned indices to produce your new classification scheme.
The example #2 could be modified to turn it into a generator from a list comprehension.
I will post more on my blog when I get some more time and report back here.  These nested, multilevel if, else if, adnauseum, else statements have to go .
The final link with code blocks using numpy and bisect modules
List comprehensions 3 ...
if - elif - elif - elif - else  free examples
