Calculate field conditional statement using a date formula
12006
11
02-09-2016 10:25 PM
MoyaCalvert
Hi all,
I am using ArcGIS 10.3 to update a field with a numeric value that represents the elapsed time since the data was captured.  I can do this in a python script that I have attached to a model but I also want to be able to sometimes do it quickly from within ArcGIS desktop and I am stumped.
I have written a 3 step process:
1. Create an integer field then calculate the number of days since today (field name = ET):
In Field Calculator, ET =
(datetime.datetime.now() - arcpy.time.ParseDateTimeString(!ActivityDate!)).days
2.  Create a conditional Statement for "Elapsed Time" field as follows:
Expression:
Reclass(!ET!)
def Reclass(ET):
    if ( ET < 28):
        return 1
    elif ( ET>= 28 and ET < 91):
        return 2
    elif ( ET >= 91 and ET < 182):
        return 3
    elif ( ET >= 182 and ET < 365):
        return 4
    elif (ET >= 365):
        return 5
3. Delete the ET field
I really just want to declare a variable in my conditional statement for ET which would save having to create then delete the ET field, but everything I have tried does not work, for example:
Expression:
Reclass(ET)
ET = (datetime.datetime.now() - arcpy.time.ParseDateTimeString(!ActivityDate!)).days
def Reclass(ET):
    if ( ET < 28):
        return 1
etc etc
I cannot find any examples of conditional statements that use a variable instead of a field value in the Field Calculator, so any help would be appreciated.
MoyaCalvert
OK thanks Dan! Below is what worked.  (It didnt work if I parsed the ET function into nowww before the def block though).
Expression:
Reclass(!ActivityDate!)
     import datetime
     def Reclass(DateFld):
         ET = (datetime.datetime.now() - arcpy.time.ParseDateTimeString(DateFld)).days
         if (ET < 28):
             return  1
          elif (ET >= 28 and ET < 91):
               return 2
          elif (ET >= 91 and ET < 182):
               return 3
          elif (ET >= 182 and ET < 365):
               return 4
          elif (ET >= 365):
               return 5
NeilAyres
And what errors are you getting?
Have you imported the datetime module?
MoyaCalvert
The error says Error 000989: Python syntax error: Parsing error SyntaxError: invalid syntax (line 1).
I dont import the datetime module in Field Calculator.
The code for calculating the difference between today and and the collection day as an integer value works fine in Field calculator  but its not happy when you try to create a variable using the same code.ETError.PNG
DanPatterson_Retired
you need to import datetime... just put it in front of the def line
XanderBakker
Esri Esteemed Contributor
... and if it is not the missing import statement, you may want to look at the content of the field !ActivityDate!. If the content is not valid and cannot be parsed to a datetime it will fail at arcpy.time.ParseDateTimeString(!ActivityDate!)
MoyaCalvert
Unfortunately the import datetime does not work - I'm still getting the same error.
just to re-iterate, I am using arcGIS 10.3 desktop and am using the Calculate Field tool.
The code now looks like this (but doesn't work):
     import datetime
     def Reclass(ET):
         if (ET < 28):
             return  1
             return 2
             return 3
             return 4
         elif (ET >= 365):
             return 5
!ActivityDate! content does contain valid date values and the code string
works fine on its own, just wont work when I use it in this context.
ET should be inside the def, just after it
def Reclass(a_fld)
ET = blah blah blah ...TimeString( a_fld )
Reclass(!ActivityDate! ) should be in the timelapesed = box
You pass a field to the function
The function will contain a variable name, it shouldn't be the actual field name
your ET function should be within the def block not before
You should really parse the ET function into
nowww = (datetime.datetime.now()   # before the code block
ET = (nowww - the reset of the original equation)
MoyaCalvert
OK thanks will try that
MoyaCalvert
Expression:
     import datetime
         if (ET < 28):
             return  1
               return 2
               return 3
               return 4
          elif (ET >= 365):
               return 5
MoyaCalvert
PS I just tried it without import datetime and it still works (which makes sense)
