Calculate daily average of raster files based on their names in python
10111
27
06-13-2017 10:15 AM
AmenehTavakol
I have hundreds of SMAP soil moisture data and need to calculate the daily average of them. For every day there are 8 files (every 3 hours) and I need a code to calculate the average based on their names.
I have a code but i am interested to know how can I define a code that average data based on their names?
# Import arcpy module
import arcpy
# Local variables:
SMAP_L4_SM_gph_20150331T043000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c15_tif = "SMAP_L4_SM_gph_20150331T043000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c15.tif"
SMAP_L4_SM_gph_20150331T073000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0d_tif = "SMAP_L4_SM_gph_20150331T073000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0d.tif"
SMAP_L4_SM_gph_20150331T103000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c14_tif = "SMAP_L4_SM_gph_20150331T103000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c14.tif"
SMAP_L4_SM_gph_20150331T133000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf5_tif = "SMAP_L4_SM_gph_20150331T133000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf5.tif"
SMAP_L4_SM_gph_20150331T163000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf3_tif = "SMAP_L4_SM_gph_20150331T163000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf3.tif"
SMAP_L4_SM_gph_20150331T193000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf4_tif = "SMAP_L4_SM_gph_20150331T193000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf4.tif"
SMAP_L4_SM_gph_20150331T223000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0f_tif = "SMAP_L4_SM_gph_20150331T223000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0f.tif"
SMAP_L4_SM_gph_20150331T013000_Vv2030_001_Geophysical_Data_sm_surface_bdea9eb8_tif = "SMAP_L4_SM_gph_20150331T013000_Vv2030_001_Geophysical_Data_sm_surface_bdea9eb8.tif"
v_name_ = "D:\\NASA\\Data\\SMAP\\2014\\Processed\\%name%.tif"
# Process: Raster Calculator
arcpy.gp.RasterCalculator_sa("( \"%SMAP_L4_SM_gph_20150331T043000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c15.tif%\" + \"%SMAP_L4_SM_gph_20150331T073000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0d.tif%\" + \"%SMAP_L4_SM_gph_20150331T103000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c14.tif%\" +\"%SMAP_L4_SM_gph_20150331T133000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf5.tif%\" + \"%SMAP_L4_SM_gph_20150331T163000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf3.tif%\" + \"%SMAP_L4_SM_gph_20150331T193000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf4.tif%\" + \"%SMAP_L4_SM_gph_20150331T223000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0f.tif%\" + \"%SMAP_L4_SM_gph_20150331T013000_Vv2030_001_Geophysical_Data_sm_surface_bdea9eb8.tif%\") / 8", v_name_)
Your help is really appreciated.
AmenehTavakol
I put the final codes to help others with the same question:
import arcpy
from shutil import copy2
from collections import defaultdict
def main():
    raster_dir = r"D:\NASA\Data\SMAP\OutPut"
    arcpy.env.workspace = raster_dir
    raster_days = defaultdict(list)
    for r in arcpy.ListRasters():
        raster_days[r[15:23]].append(r)
    for date, rasters in raster_days.items():
        print(date)
        outCellStatistics = arcpy.sa.CellStatistics(rasters, "MEAN")
        copy2(r"D:\NASA\Data\SMAP\OutPut\meanc_ras.tif",
              r"D:\NASA\Data\SMAP\OutPut\Processed\meanc_ras_{}.tif".format(date))
if __name__ == '__main__':
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
BlakeTerhune
In the future, try Posting code with Syntax Highlighting on GeoNet. Makes code easier to read and copy.
curtvprice
I went ahead and fixed it.
AmenehTavakol
Dear all,
This is my last code: I need to copy my output file in a folder:
import arcpy
# Check out the ArcGIS Spatial Analyst extension license
def main():
        print(date)
        #for r in rasters:
            #print("\t{}".format(r))
        #outname = r"D:\NASA\Data\SMAP\OutPut\Processed"
        #outCellStatistics.save(outname)
        copy2("D:\NASA\Data\SMAP\OutPut\meanc_ras.tif","D:\NASA\Data\SMAP\OutPut\Processed\meanc_ras_{}.tif".format(date))
But now I receive an error :
IOError: [Errno 2] No such file or directory: 'D:\\NASA\\Data\\SMAP\\OutPut\\meanc_ras.tif'
I don't know how to save my results!
BlakeTerhune
Looking at the code samples, try
outCellStatistics.save(r"D:\NASA\Data\SMAP\OutPut\Processed\outCellStatsImage.tif")‍‍‍‍‍
LarryBiodun
Hello everyone.  I am trying to do a similar thing to the original post however, I have thousands of daily files that I want to use the cell statistics to calculate the 8 day averages. Simply put instead of the final code above doing a mean of the daily values, I want the code to do a mean after every eight days and save each file with the beginning date of each 8 day average. Your help is greatly appreciated!
XanderBakker
Esri Esteemed Contributor
Hi Larry Biodun , it is better to create a new question and provide more information on the input data (names for instance and storage type) and if possible attach some data. Depending on the names we can see if a similar approach can be applied to your problem.
When you create a new question do include a link to this thread.
LarryBiodun
Thanks Xander. I'll do that now
