Calculate daily average of raster files based on their names in python
10093
27
06-13-2017 10:15 AM
AmenehTavakol
I have hundreds of SMAP soil moisture data and need to calculate the daily average of them. For every day there are 8 files (every 3 hours) and I need a code to calculate the average based on their names.
I have a code but i am interested to know how can I define a code that average data based on their names?
# Import arcpy module
import arcpy
# Local variables:
SMAP_L4_SM_gph_20150331T043000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c15_tif = "SMAP_L4_SM_gph_20150331T043000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c15.tif"
SMAP_L4_SM_gph_20150331T073000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0d_tif = "SMAP_L4_SM_gph_20150331T073000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0d.tif"
SMAP_L4_SM_gph_20150331T103000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c14_tif = "SMAP_L4_SM_gph_20150331T103000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c14.tif"
SMAP_L4_SM_gph_20150331T133000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf5_tif = "SMAP_L4_SM_gph_20150331T133000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf5.tif"
SMAP_L4_SM_gph_20150331T163000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf3_tif = "SMAP_L4_SM_gph_20150331T163000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf3.tif"
SMAP_L4_SM_gph_20150331T193000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf4_tif = "SMAP_L4_SM_gph_20150331T193000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf4.tif"
SMAP_L4_SM_gph_20150331T223000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0f_tif = "SMAP_L4_SM_gph_20150331T223000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0f.tif"
SMAP_L4_SM_gph_20150331T013000_Vv2030_001_Geophysical_Data_sm_surface_bdea9eb8_tif = "SMAP_L4_SM_gph_20150331T013000_Vv2030_001_Geophysical_Data_sm_surface_bdea9eb8.tif"
v_name_ = "D:\\NASA\\Data\\SMAP\\2014\\Processed\\%name%.tif"
# Process: Raster Calculator
arcpy.gp.RasterCalculator_sa("( \"%SMAP_L4_SM_gph_20150331T043000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c15.tif%\" + \"%SMAP_L4_SM_gph_20150331T073000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0d.tif%\" + \"%SMAP_L4_SM_gph_20150331T103000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c14.tif%\" +\"%SMAP_L4_SM_gph_20150331T133000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf5.tif%\" + \"%SMAP_L4_SM_gph_20150331T163000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf3.tif%\" + \"%SMAP_L4_SM_gph_20150331T193000_Vv2030_001_Geophysical_Data_sm_surface_bdea9bf4.tif%\" + \"%SMAP_L4_SM_gph_20150331T223000_Vv2030_001_Geophysical_Data_sm_surface_bdea9c0f.tif%\" + \"%SMAP_L4_SM_gph_20150331T013000_Vv2030_001_Geophysical_Data_sm_surface_bdea9eb8.tif%\") / 8", v_name_)
Your help is really appreciated.
AmenehTavakol
Right now I have to calculate the average for every cluster which is in this shape,
20150429
SMAP_L4_SM_gph_20150429T013000_Vv2030_001_Geophysical_Data_sm_surface_bf1ec829.tif
SMAP_L4_SM_gph_20150429T043000_Vv2030_001_Geophysical_Data_sm_surface_bf1ec80f.tif
SMAP_L4_SM_gph_20150429T073000_Vv2030_001_Geophysical_Data_sm_surface_bf1ec7e9.tif
SMAP_L4_SM_gph_20150429T103000_Vv2030_001_Geophysical_Data_sm_surface_bf1ecad1.tif
SMAP_L4_SM_gph_20150429T133000_Vv2030_001_Geophysical_Data_sm_surface_bf1ec808.tif
SMAP_L4_SM_gph_20150429T163000_Vv2030_001_Geophysical_Data_sm_surface_bf1ec82d.tif
SMAP_L4_SM_gph_20150429T193000_Vv2030_001_Geophysical_Data_sm_surface_bf1ec7eb.tif
SMAP_L4_SM_gph_20150429T223000_Vv2030_001_Geophysical_Data_sm_surface_bf1ec82a.tif
But I could not do that through getproperties and this code:
for rasters in main():
    Ave = np.mean()
So how can i define the average for every cluster?
BlakeTerhune
Check out the Cell Statistics tool that Curtis Price‌ mentioned. It takes a list of raster filenames and calculates an output raster with whatever summary statistic type you choose. Using my file grouping code above, you can do something like...
for date, rasters in raster_days.items():
    # Execute CellStatistics
    outCellStatistics = arcpy.sa.CellStatistics(rasters, "MEAN")
    # Save the output
    outCellStatistics.save("C:/example/cellstats_output")‍‍‍‍‍‍
Note that it looks like you do need the spatial analyst extension for Cell Statistics.
# Check out the ArcGIS Spatial Analyst extension license
AmenehTavakol
import arcpy
import numpy as np
from collections import defaultdict
def main():
    raster_dir = r"D:\NASA\Data\SMAP\OutPut"
    arcpy.env.workspace = raster_dir
    raster_days = defaultdict(list)
    for r in arcpy.ListRasters():
        raster_days[r[15:23]].append(r)
        print(date)
        for r in rasters:
            print("\t{}".format(r))
if __name__ == '__main__':
    main()
for date, rasters in raster_days.item():
        # Save the output
        outCellStatistics.save("D:/NASA\Data\SMAP\OutPut/Processed")
I tried this one but I received an error "for date, rasters in raster_days.item():
                                                              NameError: name 'raster_days' is not defined"
curtvprice
Blake there is a typo in your code above I think
    for date, rasters in day_rasters.items():
should be
AmenehTavakol
They are "for date, rasters in raster_days.item():"
But still I receive this error!! that "NameError: name 'raster_days' is not defined".
curtvprice
That's because you put that code in the wrong place -- outside of the main() function.
The variable raster_days is not defined outside of the function.
BlakeTerhune
Yes, I see it now, thanks. I'll update my code.
curtvprice
I think you want to look into the Cell Statistics tool. The order doesn't matter, you could use Model Builder‌ or Python (arcpy.ListRasters() or arcpy.da.Walk) to create your list of rasters and pass it to the tool.
AmenehTavakol
Do you have an example of the code. I am very new in python so your help is really appreciated.
curtvprice
