Calculate Area Add In - problem with multiple dataset types
1139
05-02-2014 10:02 AM
SarahFranklin
I am working on what I thought was a simple button to calculate the area of a selected polygon.. however the script fails if there is a raster dataset loaded in the .mxd - even if it is not selected, due to the FIDSet command.. any ideas on how to get around this (other than removing the raster)?
Code in reply below...
SarahFranklin
Sorry.. here's the formatted version of the code
        if testCount==0:
            msg = "You must first add a polygon layer or feature class and select some features to report their acreage."
            pythonaddins.MessageBox(msg, 'Area Report', 0)
        else:
            for lyr in arcpy.mapping.ListLayers(mxd):
                if lyr.isGroupLayer:
                    for sublyr in lyr:
                        tlyr = lyr
                else:
                    tlyr = lyr
                    dsc = arcpy.Describe(tlyr)
                    sel_set = dsc.FIDSet
                    if dsc.shapeType == "Polygon":
                        if len(sel_set) > 0:
                            with arcpy.da.SearchCursor(tlyr, ("OID@", "SHAPE@AREA")) as cursor:
                                for row in cursor:
                                    parea = row[1] + parea
                                    resSQFT = parea
                                    resAC = parea / 43560
                                    resHA = parea / 107639.104
SarahFranklin
        if testCount==0:
        else:
                    for sublyr in lyr:
                        tlyr = lyr
                else:
                    tlyr = lyr
                                for row in cursor:
                                    resSQFT = parea
