Bypass Nulls or blanks
2534
7
11-07-2018 02:51 PM
CCWeedcontrol
I have the following and i get 'NoneType' object has no attribute 'strip' on line 10. There are some records that have NULL or Blanks in the ACCOUNT field. How do i bypass or skill the ones that are null or blank?
try:
    #build a dictionary of ACCOUNT : Address pairs
    addDict = {row[0]:row[1] for row in arcpy.da.SearchCursor(fc1,['ACCOUNT','SiteAddress'])}
    #search through fc2 to see if addresses match based on ACCOUNT value
    with arcpy.da.UpdateCursor(fc2, ['Account','SiteAddres','Verifi2']) as cursor:
        for row in cursor:
            if row[1] != None:
                if row[0] in addDict:
                    if row[1].strip().lower()!= addDict[row[0]].strip().lower(): #if the value associated with those ids do not match
                        row[2] = 'No'
                    else:
                        row[2] = 'Match'
                    cursor.updateRow(row)
    del cursor
JoshuaBixby
MVP Esteemed Contributor
Stylistically, my_var is None is more Pythonic than my_var == None.  Style aside, you are making sure that row[1] is not None, but you haven't done the same with row[0].  Instead of suggesting you just add another conditional check, what do you want to do when either Account, SiteAddres, or both are NULL in the table?
CCWeedcontrol
I would like to just bypass them and continue to check for matches.
JoeBorgione
When is a blank a blank?
''  or ' ' or '   ' or '              '
For those of you old enough to have listened to real vinyl, my blank and <null> rants must sound like a broken record.
Image result for broken record gif
That should just about do it....
DanPatterson_Retired
NONE.... not again
another option in case you have multiple conditions.
if row[1] not in (None, 'None', 'NoneType', '', "", " ", 'nOnE':
    # carry on because there is no None-nonsense
CCWeedcontrol
What if fc1 has blanks? i guess i didn't think about that till now.
CCWeedcontrol
Sorry to bring this back up but i am still having issues.
also the issue with if fc1 doesn't have anything in the "ACCOUNT" field how do you just keep the update cursor going on to the next one?
try:
        for row in cursor:
            if row[1] != None:
                    if row[0] != None:
                            row[2] = 'No'
                        else:
                            row[2] = 'Match'
    del cursor
if row[whatever] != None:
change to,
if row[whatever] is not None:
generally safer.
Now if line 3 doesn't have anything? you want to continue on to where?
because on line 9 checks to see if fc2 has 'Account' in the previously created dictionary... if it doesn't, it just goes on to the next row, which is what is coded, hence there is no update.
Perhaps you can throw in some print statements to illustrate what is being printed at each stage and where you want it to go.
Also, try-except blocks are pretty useless you have some code to handle the 'fail' conditions. What is beyond line 16?
