Best Practices for selecting a feature from a feature class that was just created.
1918
05-16-2025 12:01 PM
ZacharyKasson
I'm wondering what's the best practice is 4 selecting features of a feature class that was just created in the same tool.
This code works perfectly fine when I am running it in a notebook in pro. I get the expected amount of features in my output feature class. I presume this works because it adds the feature to my map and is able to select the desired features.
    arcpy.conversion.ExportFeatures(
        in_features=in_features,
        out_features= output_path,
        where_clause="Status = 'Confirmed'",
        use_field_alias_as_name="NOT_USE_ALIAS",
        field_mapping= field_mapping
    arcpy.AddMessage('Exported routes')
    arcpy.management.SelectLayerByLocation(
        in_layer= f"{output_file_name}",
        overlap_type="INTERSECT",
        select_features=f"{feature1}",
        search_distance="5 Meters",
        selection_type="NEW_SELECTION",
        invert_spatial_relationship="NOT_INVERT"
    arcpy.management.DeleteRows(output_file_name)
        select_features=f"{feature2}",
        invert_spatial_relationship="INVERT"
 but when I turn this into a tool the output feature class has 0 features in it. I'm guessing this does not work because it cannot select features of a feature class that is not in my map.
I have tried to add the newly created feature class to my map using a couple different methods: Screenshot 2025-05-16 145837.jpg
These return a layer object but the layer is not added to my map.
I guess the overall question is: what is the best way to approach making a selection from a feature class that has just been created?
TonyAlmeida
MVP Regular Contributor
Use arcpy.MakeFeatureLayer_managment prior to SelectLayerByLocation
Something like this,
# Create selection feature layer (your exact format)
Sel_Point = arcpy.MakeFeatureLayer_management(
    selection_feature,
    "point_layer",
    "\"FID\"={}".format(str(fid_value)) #or OID
# Perform selection
    in_layer=output_file_name,
    select_features=Sel_Point,  # Using the variable you created
TonyAlmeida
    selection_feature,
    "point_layer",
# Perform selection
ZacharyKasson
I noticed that you assigned the result of arcpy.MakeFeatureLayer_management to a variable named Sel_Point.
Is it considered best practice to store the output of a tool in a variable like this? Does assigning it to a variable improve the tool’s performance or is it mainly for readability and convenience?
TonyAlmeida
Yes, it is best practice. It would be more for readability than anything, in my opinion.  it does nothing for performance that I am aware of.
GISDepartmentMFM
it also lets you add it to the map
map.addLayer(Sel_Point.getOutput(0))
