Best practice for paths - arcpy.env.workspace vs os.path.join
4494
6
05-21-2013 04:15 PM
MatthewBrown1
I've recently had an odd error and found it was due to the way I set up the input. The really odd thing is that some tools worked, but another (arcpy.CalculateStatistics_management) failed with the error:
Failed to execute. Parameters are not valid.
ERROR 000840: The value is not a Mosaic Dataset.
ERROR 000840: The value is not a Mosaic Layer.
ERROR 000840: The value is not a Raster Dataset.
Even though checking the input showed it to be valid raster dataset.
Here's the code that failed:
arcpy.CalculateStatistics_management("demExtract","1","1","#","OVERWRITE")
If I put the full path, it worked. Seems that setting arcpy.env.workspace didn't work for this tool. Using this worked:
arcpy.CalculateStatistics_management((os.path.join(gdbPath, "demExtract")),"1","1","#","OVERWRITE")
Is os.path.join something that should be used by default?
ChrisSnyder
Honored Contributor
Shouldn't:
arcpy.CalculateStatistics_management("demExtract"),"1","1","#","OVERWRITE")
be
As long as your arcpy.env.workspace is set to where the raster "demExtract" lives, then it should work. I would refrain from naming files with camelCase and name it "dem_extract" instead.
That said about arcpy.env.workspace, I usually provide the tools with a datset's full path instead of relying on the assumption that all my input datasets are coming from the same workspace, which they often do not.
Per your question about a best practices, I am in the (bad) habit of using a harcoded '\\' as my path seperator, and it is much more correct to use os.path.join or os.path.sep to ensure that you are being OS-specific. I only use windows so '\\' works for me. However, if ArcGIS ever gets ported to UNIX or something, I'll be in a world of hurt updating my code...
MatthewBrown1
Shouldn't:
be
Yep! Lazy mistake after copy & paste.
Funny about the camelCase - I normally do use underscores but was told to change for this project. Does anyone have formal coding standards for Python and ArcGIS they can share?
RyanMonk1
Looks like Python code written by Esri uses underscores, for example look in:
C:\Program Files (x86)\ArcGIS\Desktop10.4\arcpy\arcpy\sa\Functions.py
However many of the examples written by Esri in the arcpy reference use camelCase, but I've seen instances where they are inconsistent.
Python style guide says lower_with_under
PEP 8 -- Style Guide for Python Code | Python.org
Google style guide says lower_with_under
Google Python Style Guide
DanPatterson_Retired
The key is, ... it is a guide ... not rules .... can't find the exact link, but even Python's BDFL said as much
ClintonDow1
Yes typically I would recommend getting used to PEP8 style, it is used for the majority of Python projects and is something that is appreciated during coding interviews  ArcPy actually breaks PEP8 in a lot of places for a number of historical reasons, so its not the best reference for the canonical Python style.
Edit: Late to the party. Oh well.
curtvprice
The biggest danger of using local path names I have run into is that they can conflict with layer names in your map. If you have a dataset named "foo" in your workspace and a layer named "foo" in your map (or in memory), the layer will be used. Took me a while to figure that one out.
