Batch Zonal Statistics Script - Error 010423
5896
10
05-19-2014 01:10 PM
N__R_Wilson
I created a script to batch process Zonal Statistics as Table with user inputs, option to add a field, and a single appended table as an output.
It runs fine with some data. But with other data it throws a ERROR 010423: N:\Gabions\NDVI\35_38_May_June\t_t324 does not have valid statistics as required by the operation
When I modify the code to run from PyScripter it works fine and doesn't throw the error. (Modifications: hard-code the inputs, change AddMessage/AddWarning to print.) I haven't been able to find much information on this error within a python setting.
I tried adding Calculate Statistics just before the Zonal Statistics as Table but nothing changed...
arcpy.CalculateStatistics_management(raster,"","","","OVERWRITE",zonefile)
I'm pretty new to scripting. Any help?
# Import modules
import arcpy
import os
import shutil
# Get parameters
indir = arcpy.GetParameterAsText(0)
zonefile = arcpy.GetParameterAsText(1)
addfield = arcpy.GetParameterAsText(2)
startcharin = arcpy.GetParameterAsText(3)
endcharin = arcpy.GetParameterAsText(4)
outdir = arcpy.GetParameterAsText(5)
outfile = arcpy.GetParameterAsText(6)
# Set variables for zonal statistics and add field routines
zonefield = "UID"
startchar = int(startcharin) - 1
endchar = int(endcharin) - 1
outtable = ""
year = ""
# Set global environments and make scratch
scratchdir = "C:\\TEMP\\Scratch\\ZoneStatsBatch"
if not os.path.exists(scratchdir):
    os.makedirs(scratchdir)
# Check the input data
fieldlist = arcpy.ListFields(zonefile,"*","ALL")
fieldnames = []
for field in fieldlist:
    fieldnames.append(field.name)
if not "UID" in fieldnames:
    arcpy.AddWarning(zonefield + " field does not exist in " + zonefile)
arcpy.env.workspace = indir
rasters = arcpy.ListRasters("*")
if not rasters:
    arcpy.AddWarning(indir +" contains no rasters \nZonal statistics failed")
# Zonal Statistics
index = 0
for raster in rasters:
    outtable = scratchdir + "\\scratchouttable" + str(index) + ".dbf"
    arcpy.sa.ZonalStatisticsAsTable(zonefile,zonefield,raster,outtable,"DATA","ALL")
    arcpy.AddMessage("Zonal statistics have been calculated for raster: " + raster)
# Add Field and Calculate Field if addfield boolean = True
    if addfield:
        try:
            year = raster[startchar:endchar]
            arcpy.AddField_management(outtable, "Year", "TEXT", "", "", 4)
            arcpy.CalculateField_management(outtable, "Year", year, "PYTHON")
            arcpy.AddMessage ("Year field (" + year + ") has been calculated for raster: " + raster)
        except:
            arcpy.AddWarning("Add year field failed")
    index = index + 1
# Set local variables and environment for Append
arcpy.env.workspace = scratchdir
outfiledbf = outfile +".dbf"
template = outtable
config_keyword = ""
outfullpath = outdir + "\\" + outfiledbf
schemaType ="NO_TEST"
fieldMappings = ""
subtype = ""
# Append
try:
    tablelist = arcpy.ListTables("*")
    arcpy.CreateTable_management(outdir, outfiledbf, template, config_keyword)
    arcpy.Append_management(tablelist, outfullpath, schemaType, fieldMappings, subtype)
    arcpy.AddMessage("Batch zonal statistics output table located at: " + outdir + "\\" + outfiledbf)
except:
    arcpy.AddWarning("Table append failed")
# Clean up your mess! (delete scratch)
try:
    shutil.rmtree(scratchdir,ignore_errors = "TRUE", onerror = "NONE")
    arcpy.AddMessage("Scratch workspace cleared")
except:
    arcpy.AddWarning("Scratch workspace not cleared: " + scratchdir)
RhettZufelt
MVP Notable Contributor
Might want to put some print/addmessage statements in there and look at the parameters that are being passed.
I say this as the last time I had something working fine in stand alone, it would not function properly in a script tool.
Basically if I had something like this:
intext = arcpy.GetParameterAsText(0)    # from text input box in tool
and I enter "test text" (without the quotes of course)
>>>print intext
"test text"
However, in stand alone if I set:
>>>intext = "test text"
>>>print intext
test text
To match the same format in stand alone, I need to do something similar to:
>>>intext = '"' + "test text" + '"'
>>>print intext
"test text"
as you can see, when it gets passed as a parameter as text, the variable value includes the double quotes.  If you just set a variable equal to a text value, the double quotes are not there.
Just a thought as the first time I ran into this it took me a while to realize the two outputs were different (one had quotes).
R_
