batch domain list
466
01-26-2026 12:55 PM
rami_shah
Hi folks,
I am looking for python script that extract all domains where
code <> description
from SDE(oracle) database. any sample code that I could reuse is greatly appreciated.
Ram
DavidSolari
MVP Regular Contributor
The List Domains function is what you're looking for, this will work on any EGDB. The sample code on that page should get you started.
AlfredBaldenweck
MVP Frequent Contributor
Something like this
egdb = r"GDB.sde"
badDomains = []
for dom in arcpy.da.ListDomains(egdb):
    if dom.domainType == "Range":
        continue
    for key in dom.codedValues:
        if key!= dom.codedValues[key]:
            badDomains.append(dom.name)
print("done")
print(badDomains)
HaydenWelch
NOTE: In your version, if a domain has multiple non-matching values, it is added multiple times.
You can also do this in a dictionary comprehension:
def bad_domain(dataset: str):
    from arcpy.da import ListDomains
    return {
        d.name: d
        for d in ListDomains(dataset)
        if d.domainType == 'CodedValue'
        and not all(
            value_key == value_description
            for value_key, value_description in d.codedValues.items()
I usually like to unroll these types of filters into multiple functions so it's clear exactly what checks are being made:
from typing import Any
from arcpy.da import Domain
def is_bad_values(val: dict[Any, str]):
    any(k != v for k, v in val.items())
def is_bad_domain(d: Domain):
    return d.domainType == 'CodedValue' and is_bad_values(d.codedValues)
def bad_domains(dataset: str):
    return {d.name: d for d in ListDomains(dataset) if is_bad_domain(d)}
If you want to get REALLY re-usable, you can use a registration pattern:
from collections.abc import Callable
from functools import wraps
type DomainValidator = Callable[[Domain], bool]
Validators: list[DomainValidator] = []
VALID = True
INVALID = False
def register_validator(func: DomainValidator):
    Validators.append(func)
    @wraps
    def _wrapper(*args: Any, **kwargs: Any):
        return func(*args, **kwargs)
    return _wrapper
@register_validator
def domain_value_check(d: Domain):
    if d.domainType == 'CodedValue' :
        if any(k != v for k, v in d.codedValues.items()):
            return INVALID
    return VALID
@register_validator
def domain_range_check(d: Domain):
    if d.domainType == 'Range':
        min, max = d.range
        if not isinstance(min, (int, float)):
            return INVALID
        if not isinstance(max, (int, float)):
            return INVALID
        if min < 0 or max > 100:
            return INVALID
    return VALID
def bad_domains(dataset: str, validators: list[DomainValidator]=Validators):
    return {
        d.name: d
        if any(validator(d) is INVALID for validator in validators)
Now you can just add and remove validations as you please.
