Basic Question for arcpy.mp.ArcGISProject()
1621
07-06-2021 09:07 PM
kelvpau
Hi, I just have a basic question with the arcpy.mp.ArcGISProject()  function while trying to follow along a simple tutorial that is a bit old. Here's the relevant code section below
# Import modules
import arcpy
# Create the map document object
aprx = arcpy.mp.ArcGISProject(r"C:\Users\User\Documents\ArcGIS\Projects\MyProject2.aprx")
And this is the OS Error in question:
File "C:\Users\User\Desktop\Exercise ArcGis Python\Ex_Files_ArcGIS_Python_Scripting\Exercise Files\WorkWithListsFinal.py", line 15, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\_mp.py", line 344, in __init__
self._arc_object = arcgisscripting._mapping.ArcGISProject(*gp_fixargs((aprx_path,), True))
OSError: C:\Users\User\Documents\ArcGIS\Projects\MyProject2.aprx
Not really sure what's happening here to not allow me reference the .aprx file which is what I thought the ArcGISProject() command did.
JayantaPoddar
From Windows Explorer, could you ensure that the filepath of the aprx file is correct?
Just my assumption, maybe you missed the folder containing the aprx file (e.g. "C:\Users\User\Documents\ArcGIS\Projects\MyProject2\MyProject2.aprx")
or any other pathname
Think Location
DanPatterson
MVP Esteemed Contributor
unless you altered the path
probably should be
 C:\Users\.. your user name ...\Documents\ArcGIS\Projects\MyProject2.aprx
where  "your user name" is your identifier
... sort of retired...
