autoIncrement block not working within a Python Toolbox?
2693
6
05-21-2022 04:24 PM
DPG
Hey guys. I am creating a python toolbox that assigns selected polygons in a shapefile a unique id. This id features a section of string followed by a sequential ID. However, whenever I insert the following code block for autoIncrement into my script, the tool will no longer launch. This is the autoincrement block I have taken from ArcGIS Resources:
        rec = 0
def autoIncrement():
 global rec
 pStart = 1 #adjust start value, if req'd
 pInterval = 1 #adjust interval value, if req'd
 if (rec == 0):
  rec = pStart
 else:
  rec = rec + pInterval
 return rec
I am placing it in the " def execute(self, parameters, messages):" section of the python toolbox template.
Any ideas as to why this is causing my script to fail? Thank you!
DonMorrison1
Ah - now I see.  Lines 12  and 13 are indented incorrectly.
DonMorrison1
It would be most helpful if you could post the error message, as well as the complete python file. I don't think there is anything wrong with the snippet you posted so there must be something else. Thanks
DPG
I'm afraid there is no error message. Where I can usually select the script (seen here as "Tool")...
... After pasting in that code block into the script, the option disappears as shown here:...
DonMorrison1
If you right click on TestToolbox.pyt do you get an option to "Check Syntax"?
DPG
Here's the error:
For context, here's this part of the code:
        # Sequential Formula
        rec = 0
            global rec
            if (rec == 0):
                rec = pStart
                else:
        return rec
Apologies for the lack of clarity. Line 112 is line 12 in my pasted code.
DonMorrison1
DPG
Wow, how foolish of me. Thank you! Think I've been staring at code for too long.
