AttributeError: <unprintable AttributeError object>  when running on ArcGIS10
5858
15
02-18-2011 12:27 PM
hanyhassaballa
i have installed ArcGIS 10, and i am getting this error:
when i am trying to run python script that were develop in ArcGIS 9.3, what could be the problem.
ChristopherStorer
My fault, I'm used to working in more complex environments.  Take out the loggers and use print statements to send the errors to the screen:
    try:
        print("Place code here")
    except arcpy.ExecuteError:
        Errors = "TRUE"
        print("An error occurred during geoprocessing:")
        print(arcpy.GetMessages(2))
    except Exception as ErrorDesc:
        Errors = "TRUE"
        print("An unknown error occurred:")
        print(ErrorDesc.message)
yoanndrocourt
ok, that is becoming clrearer now...
so it seems that it doesn't find the toolbox right?
but I am importing it...don't really know what I can do...I was wondering if the space in the nam eof the toolbox could cause this to happen.
F:\front\trash\test.py:41: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
  logger.error(ErrorDesc.message)
Object: Tool or environment <????????????????????> not found
ChristopherStorer
I can't imagine the space being a problem, but it's worth trying.  I would think if the tool truly didn't exist, it would have failed at the top while you were trying to import it.
George_ChandeepCorea
Greetings...was there a fix to this?
I get the following...
  File "<pyshell#0>", line 1, in <module>
    arcpy.CopyFeatures_management(polygon, ShapeFile_prj)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 1943, in CopyFeatures
    raise e
where
>>> polygon
<Polygon object at 0xf34f550[0x347d9e0]>
>>> ShapeFile_prj
'F:\\vector\\Biboohra_Koah\\25cm\\TPE0_330000_8135000_1k_cont.shp'
My full script is attached. This should work on any directory with ESRI readable vector files.
best,
curtvprice
I have seen this AttributeError when there are two toolboxes active with the same alias. In this situation, ArcGIS has trouble accessing the correct tool because of the alias conflict.
LaurensKusse
Right mouse click on the toolbox, select properties and add an alias on the General tab, solved this problem for me.
