AsShape Opposite
1670
08-09-2012 11:05 AM
KeithSandell
Anyone know if there is a Geom to Json in python?
Essentially the opposite of arcpy.AsShape(), Json to Geometry object.
JasonScheirer
Esri Alum
Geometry.__geo_interface__
KeithSandell
Okay, question:
Using the geo_interface on a multi-part feature with a hole in one of the parts returns the below value for coordinates.
If you notice in the midst of the coordinates is "None". The point at which this appears, appears to be the demarcation between the part and its hole.
How is "None" going to be interpreted by a program receiving the json?
[[(-9254388.2779676616, 3457813.8078284338), (-9377036.4553730804, 3457813.8078284338), (-9377036.4553730804, 3563951.6536600441), (-9254388.2779676616, 3563951.6536600441), (-9254388.2779676616, 3457813.8078284338)], [(-9406523.9989057705, 3626128.8613477843), (-9406523.9989057705, 3519991.0155161736), (-9529172.1763111949, 3519991.0155161736), (-9529172.1763111949, 3626128.8613477843), (-9406523.9989057705, 3626128.8613477843), None, (-9499902.5223645903, 3603858.4769027131), (-9500932.2585095931, 3540838.6248286134), (-9430498.3061914891, 3542486.2026606067), (-9430910.2006494887, 3603858.4769027131), (-9499902.5223645903, 3603858.4769027131)]]
This is how the Portal API returns the same geometry:
[[[-9254388,3457814],[-9377036,3457814],[-9377036,3563952],[-9254388,3563952],[-9254388,3457814]],[[-9406524,3626129],[-9406524,3519991],[-9529172,3519991],[-9529172,3626129],[-9406524,3626129]],[[-9499903,3603858],[-9500932,3540839],[-9430498,3542486],[-9430910,3603858],[-9499903,3603858]]]
JasonScheirer
Esri Alum
AsShape and __geo_interface__ are using GeoJSON, not Esri JSON. A few years ago it was a nascent standard that looked like it would take off so we adopted it, but it hasn't found much widespread use. We'll be adding Esri JSON support to geometries so you can feed them to REST APIs in 10.1 SP1. Until then, you'll need to do your own conversions.
KeithSandell
Thanks for the explanation. Good thing I came up with this then, I was just looking for an easier way to do it.
Obviously only for polygons...
class readGeo:
    def __init__(feat, geom):
        feat.geom = geom
    def returnGeom(feat):
        fGeom = feat.geom
        partCount = fGeom.partCount
        rings = "["
        featLst = []
        vrtxNum = 0
        while vrtxNum < partCount:
            part = fGeom.getPart(vrtxNum)
            pnt = part.next()
            while pnt:
                featLst.append("[" + str(int(round(pnt.X))) + ", " + str(int(round(pnt.Y))) + "]")
                pnt = part.next()
                if not pnt:
                    for pair in featLst:
                        rings += pair + ", "
                    del featLst[:]
                    rings = rings[0:len(rings)-2] + "]"
                    pnt = part.next()
                    if pnt:
                        rings += ", ["
                    elif partCount > 1:
                        rings += ", ["
            vrtxNum += 1
        if partCount == 1:
            return rings
        else:
            return rings[0:len(rings)-3]
