ASCII to Raster Conversion
3362
10-18-2015 11:51 PM
tehreemfatima
how can I convert data in ascii format to raster using python script?
NeilAyres
Which ascii format is this then?
If it is something like *.asc with a well defined header as per this help :
ArcGIS Help 10.1
Then the Ascii Grid tool will import this into a raster.
DanPatterson_Retired
Neil is correct ... an updated link if you are using ArcMap 10.3 Ascii to raster​
When you say a python script ... skip it ... if you plan on reinventing the wheel, the script example with the tool help will allow you to access the conversion, but it will not be a script that performs the actual conversion for you.  For arcpy access, it is in the code examples as
arcpy.ASCIIToRaster_conversion(inASCII, outRaster, rasterType)
