Ascii to Raster Conversion help
4749
11
10-24-2011 10:16 AM
ClaireParsons
Hope someone can help - I've written this script several times in the past but unfortunately my laptop is being serviced and I forgot to backup my python scripts directory - ~DOH 😮
Anyway, this should be really simple - I'm looping through some ascii files in a directory and converting them to a raster.  However, Python returns the error - Failed to execute (ASCIIToRaster).
I know the ascii file is there as I have manually converted in toolbox and its fine.  I've posted the code below.
# Import arcpy module
import arcpy
from arcpy import env
# Local variables:
env.workspace = "C:/Data/asc"
outputraster = raster.rstrip("dtm.asc")
datatype = "FLOAT"
#Get a list of ascii files
rasterList = arcpy.ListRasters()
for raster in rasterList:
    arcpy.ASCIIToRaster_conversion(raster,outputraster,datatype)
JustinDix
I too am trying to batch convert 137 asc files to raster using the python script - I can make the function work for individual files:
import arcpy
arcpy.ASCIIToRaster_conversion("c:/data/elevation.asc", "c:/output/elevation", "INTEGER")
But cannot get it to batch work. I tried to follow the thread below (although I couldnt see if it was actually successful?) but to no avail. This is my first day of Python so could just be my ignorance. Any help greatfully received.
WhitneyKirkendall
Just add the path to the name of the ascii file for each member of your list as you go through a loop.
I got it to work like this...
for asc in ascList:
[INDENT]asc = path+"\\"+asc[/INDENT]
[INDENT]arcpy.ASCIIToRaster_conversion(asc, asc[:-4]+".img" , "FLOAT")[/INDENT]
