'ascii' codec can't encode character u'\u201c'
29617
28
02-12-2019 02:22 PM
JoeBorgione
Database qa/qc would be so much easier when no data is entered....
Last week I was dealing with newline characters. (see Where clause for '\n' ).  Today I'm getting the following error:
Runtime error
  File "<string>", line 26, in <module>
UnicodeEncodeError: 'ascii' codec can't encode character u'\u201c' in position 10: ordinal not in range(128)
Okay...  Best I can tell u201c is a left double quote.(http://www.fileformat.info/info/unicode/char/201C/index.htm ). I put
# -*- coding: utf-8 -*-
as the first line of my script and it still errors out.  Am I doomed, or is there a way past these special characters?
JoeBorgione
You can try and replace most of the usual non-ASCII characters, but you'll always run across another... And that's exactly what I encountered.  The field I need to edit is a 'comments/field notes' field so just about anything and everything is 'allowed'.
Ultimately, I just need to replace the newline with another symbol in the database field.  I'm not at work today so I don't have the code in front of me but I tried either the decode or encode method with an ignore argument. It didn't quite work out; I must still have a flaw in my business logic.   Thankfully this project got pushed to a back burner in favor of some others.
I'll give the encode(ascii, ignore) method approach when I get back to work.  Thanks!
DanPatterson_Retired
I suspect \ in the field, turns a lot of stuff into unicode
JoeBorgione
Could be.  This exercise just screams my disdain for free text, anything goes feilds in a data base...
RandyBurton
And auto correct can be so helpful , like adding an accented e at the end of "café" etc. and thus sending it into extended ASCII or Unicode.
python 3.6.8
uni = [u"\u2019",  u"\u201c", u"\u00a0", u"Überwald",
 u'Substrate \u201co\u201d = bedrock\nUpper reaches definitely take caution,
 high flow at this time. Lower reaches nice and easy to sample. Slick rocks. Better with multiple samplers.',
 u'Park at Spruces campground lot.\nX site (A) is just downstream of bridge. Work downstream from \u201cA\u201d site.\nSome rocks are very slippery\nSeveral large logs/debris jams in reach',
 u'\u201cBedrock\u201d is a calcified structure.\nSafe for 1-2 samplers\nGolfers utilizing course that river runs through\nCulvert at start and middle of reach\nEasy parking in golf course lot',
 u'Substrate \u201cother\u201d = bedrock',
 u'Substrate \u201co\u201d = bedrock\nSafe for 1 sampler',
 u'Lambs Canyon Creek enters Parleys at beginning of \u201cA\u201d transect. Long hike to x site.  Safe for 1 person.\n']
for i in uni:
    print(i.encode().decode())
-  Überwald
-  Substrate “o” = bedrock
Upper reaches definitely take caution, high flow at this time. Lower reaches nice and easy to sample. Slick rocks. Better with multiple samplers.
-  Park at Spruces campground lot.
X site (A) is just downstream of bridge. Work downstream from “A” site.
-  “Bedrock” is a calcified structure.
-  Substrate “other” = bedrock
Safe for 1 sampler
-  Lambs Canyon Creek enters Parleys at beginning of “A” transect. Long hike to x site.  Safe for 1 person.
JoeBorgione
Finally got resolution to this on,  thanks to Joshua at ESRI tech support.  He had me add a couple of lines to my script and all is well...
# -*- coding: utf-8 -*-   """ This has always been my very first line """"
import arcpy,time,datetime,os,sys
""" added the two lines below """
reload(sys)
sys.setdefaultencoding('utf-8')‍‍‍‍‍‍
I would have thought that line 1 would have taken care of things, but I guess not..
There is a gotcha though: I've added lines 5 and 6 to my script that is the basis of a script tool used in ArcMap or Catalog 10.6.1. If I use those two lines in a standalone script and execute from a Spyder console (associated with python 3.x) it fails.  See this stackoverflow post  that states:
Also, the use of sys.setdefaultencoding() has always been discouraged, and it has become a no-op in py3k. The encoding of py3k is hard-wired to "utf-8" and changing it raises an error.
So what's the answer?  I guess it depends.....
quit using arcmap I suppose
JoeBorgione
Yeah but.....  Our customer base is pretty broad, lots of ArcMap ArcCatalog users, and a lot of them have theirs heels dug in pretty deep.  So as sys admin types, myself and the others my team have to play to both sides of the fence. We run tons of overnight scheduled tasks for individual agency eGDBs and this will be one of them, now that I know how to avoid the errors I was encountering. It's a coin toss which way to go.
The real issue though is this interim time where python 2.x and 3.x are overlapping along with respective Arcpy functionalities.  Job security through the remainder of my career I suppose...
Luke_Pinner
MVP Regular Contributor
As I mentioned earlier the special coding: comment line only applies to string literals in your code, i.e literally written in the .py file, not to any data/variables.
The real answer is to treat your strings as unicode (cos they are when read from a cursor) and do any string munging with unicode strings, i.e univar = row[0].replace(u'\n', u'==>') then encode on output univar.encode('utf8').
