ArcSDESQLExecute support calling Functions
3453
6
05-23-2013 01:30 AM
CharlesTilly
Does the ArcSDESQLExecute class support calling Oracle functions?  If yes, does it further support the return of a ref_cursor?  I've tried
sql = "call BlahFunction()"
sdeReturn = conn.execute(sql)
Regards
JamesCrandall
Regards
I am not sure if this is supported.  We are implementing the cx_Oracle library for all of our attribute queries and other data processing (it's then utilized with arcpy in one form or another).  It is a bit of a pain to get the field mapping done, but it has been an overall great way to integrate non-spatial data stored in Oracle db's.
Here is an example of calling a function (we are not doing this yet.  We simply construct and pass in complete SQL statements to build cx_oracle cursor objects).  http://stackoverflow.com/questions/8048124/cx-oracle-can-callfunc-return-list
MarcoBoeringa
According to this 10.0 Help page, it seems to be returning either a List object in case of SQL SELECT statement, or a Boolean for fail/success when running a schema changing SQL query (DDL), or UPDATE / INSERT statement:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v00000057000000.htm
Also see this:
http://developmentfaction.blogspot.nl/2010/07/python-tip-using-arcsdesqlexecute-to.html
CharlesTilly
Thanks for the replies.  I'm aware of the options you have suggested but I really need to invoke a function because one of the parameters needs to be a clob.  I could use the cx_Oracle module but then I get back a non-ESRI cursor that I then have to convert.  Ordinarily not a big deal but I have to do this a lot on a lot of data and in the interest of performance and maintenance.  I see v.10.1 has expanded the arcpy.da module with functionality that may do the trick.
JamesCrandall
Just to throw this out there, what about NumPyArrayToTable?  Wondering if you just add the cx_Oracle cursor (from the result of your function call) into an array then let the method do the work -- rather than doing all the gymnastics to get the field mapping done.  Not sure but I may have to look into this myself.
http://resources.arcgis.com/en/help/main/10.1/index.html#//018w00000016000000
CharlesTilly
Ah yes, one of those new 10.1 arcpy.da features I was referring to.  However, I need a v.10 solution.  😛
But your idea is a good one.
Regards
JamesCrandall
Regards
doh! bummer!
