arcpy visible not working
1842
15
02-04-2014 05:09 AM
ZackBartlett
I have  a script that adds .lyr files to an MXD.
A loop then iterates through the layers in the MXD and turns them all OFF, using the lyr.visible = False function. This part of my code works.
I then want to iterate through the list again, turn on the first layer, export the map as a PDF, turn off the layer, then move onto the next layer. This is the part that doesn't work. The layers do not turn on again. The PDFs export, but they are all blank.
I've seen this question asked before, but the solutions listed don't seem to be working for me.
I've posted the code below.
LYR_list_MXD = arcpy.mapping.ListLayers(MXD,"*_env*",DF)  for LYR in LYR_list_MXD:         LYR.visible = False  MXD.save()  # Turn on each layer individually and export map as new PDF  for LYR in LYR_list_MXD:         LYR.visible = True         output_PDF = OutputPDFFolder + "\\" + str(LYR) + ".pdf"         arcpy.mapping.ExportToPDF(MXD, output_PDF)         LYR.visible = False         MXD.save()
Any suggestions would be greatly appreciated.
-Zack
ZackBartlett
What version of ArcMap is installed on the machine where it is working correctly?
What version of ArcMap is installed on the machine where it is not working correctly?
Non-working machine: 10.1, with SP1.
JoshuaChisholm
Working machine: 10.1, with SP0.
Note: I did remove the MXD.save() lines, but that shouldn't make a difference.
ZackBartlett
UPDATE:
I opened my MXD and ran the code below in the python window.
>>> import arcpy
>>> MXD = arcpy.mapping.MapDocument("CURRENT")
>>> DF = arcpy.mapping.ListDataFrames(MXD, "Layers")[0]
>>> LYR_list = arcpy.mapping.ListLayers(MXD, "*_env*",DF)
>>> for lyr in LYR_list:
...     lyr.visible = True
...     output_PDF = r"T:\JOBS\123110494\gis_data\spatial_data\project_discipline\modeling\scripts\ZB\PDF\\" + str(lyr) + ".pdf"
...     arcpy.mapping.ExportToPDF(MXD, output_PDF)
...     lyr.visible = False
...     MXD.save()
This time it worked fine. All my PDFs were exported showing the correct layer.
ZackBartlett
Joshua,
Turns out it does make a difference!!
I tried running the script with only a single MXD.save() in my code, right at the end, outside of all for loops, and it worked!
I have no idea why, but if you or anyone else out there knows why this would happen, I'd love to know the answer.
Thanks, Joshua, you solved this one without even knowing it!
-Zack
JoshuaChisholm
Geez, sorry. I should have mentioned that to start with.
I'd also be very interested to know why that made a difference.
I'm happy it worked out for you!
BradPosthumus
Joshua,
-Zack
Wow, I wouldn't have expected that! But now that you mention it, it seems like every time you use MXD.save() the changes to the MXD get lost in limbo until you delete the MXD object.  But that means you need to re-open the MXD again, which isn't ideal and your code would then look something like this:
MXD = arcpy.mapping.MapDocument(MXD_file)
DF = arcpy.mapping.ListDataFrames(MXD)[0]
LYR_count = len(LYR_list_MXD)
    LYR.visible = False
MXD.save()
del MXD
for i in range(LYR_count):
    # now you need to reopen the MXD...
    LYR = arcpy.mapping.ListLayers(MXD,"*_env*",DF)
    LYR.visible = True
    LYR.visible = False
    MXD.save()
    del MXD
Note I've only tested this when running a script outside of ArcMap and not using "CURRENT" as your map document.
