Arcpy ValueError: unconverted data remains: PM
17527
8
11-23-2016 12:38 AM
MagalyClément-Zaber
Hi!
This script works fine :
import time
from datetime import datetime
date_string = '2009-11-29 03:17 PM'
format = '%Y-%m-%d %I:%M %p'
format2 = '%m/%d/%Y %I:%M:%S %p'
my_date = datetime.strptime(date_string, format)
print my_date.strftime(format2)
Result :
11/29/2009 03:17:00 PM
But If I have "import arcpy", it doesn't work !!
import arcpy
import time
Result:
  File "E:\Scripts\1-Scripts\tests\ampm.py", line 40, in <module>
  File "C:\Python27\ArcGIS10.2\lib\_strptime.py", line 328, in _strptime
    data_string[found.end():])
My script needs arcpy, how to do the stuff without error ?
Thanks for help !
Tags (3)
ClintonDow1
This is unfortunately a namespace collision in ArcPy from the early days of its design. See import arcpy tramples datetime import for more info.
As a workaround you can use:
  1. import datetime
  2. datetime.datetime.now()
  3. import arcpy
  4. datetime.datetime.now()
Or alternatively:
  1. from datetime import datetime as dt
  2. dt.now()
  3. import arcpy
  4. dt.now()
NeilAyres
Well, format is a keyword builtin. Its a method you can apply to strings to format them.
You are replacing this with your "format time string".
What do you want to do? Make a fixed time format string == your date_string,
or,
set a variable to the current time & date?
MagalyClément-Zaber
I have dates in string format and have to put in database in a datime format.
date_string = '11/29/2019 03:17 PM'
print date_string
format1 = '%m/%d/%Y %I:%M %p'
format2 = '%Y-%m-%d %I:%M:%S'
my_date = datetime.strptime(date_string, format1)
Works fine without "import arcpy"
I found another way :
        ## self.lastUsageDate = '11/29/2019 03:17 PM'
        tmp = self.lastUsageDate.split(" ")
        format12 = '%I:%M:%S'
        format24 = '%H:%M:%S'
        my_hour = datetime.strptime(tmp[1], format12)
        if (tmp[2] == "PM"):
            my_hour += timedelta(hours=12)
        formatDate = '%m/%d/%Y'
        formatDateBase = '%Y-%m-%d'
        my_date = datetime.strptime(tmp[0], formatDate)
        return my_date.strftime(formatDateBase) + " " + my_hour.strftime(format24)
JoshuaBixby
MVP Esteemed Contributor
Something else is going on, either with additional code you haven't provided or how this "script" is being called.   I executed the code, including import arcpy, on two separate machines with two different versions of ArcGIS for Desktop, and everything ran fine.
Does the script only include the code you have provided?  If so, how are you calling the script?
MagalyClément-Zaber
I use PyScripter to call the script.
I put the minimun to test :
#-*- coding: utf-8 -*-
##import arcpy
print date_string
JoshuaBixby
I don't use PyScripter nor have it installed on any machines.  When I take the code and run it as a script file directly from the ArcGIS-bundled Python interpreter, it works fine with and without the ArcPy import statement.  I am not sure what might be going on.
ClintonDow1
  1. import datetime
  3. import arcpy
Or alternatively:
  2. dt.now()
  3. import arcpy
  4. dt.now()
BlakeTerhune
I had this problem too!. Although I never knew the cause, I found that just importing datetime (your first example) worked for me. Good to know the second option is viable too. Thanks CDow-esristaff‌!
DanPatterson_Retired
It is best to import standard modules first and in the order of their   importance.  Arcpy is not a primary module, other examples include SciPy, Pandas and NumPy which all import bits of the standards as well as bits of one another sometimes.  If you need the most current and relevant ... ordering your imports is important, since once imported, it is skipped on future attempts unless expressly done... which requires effort.
Check it out yourself, even the os modules tries to import sys.
