Arcpy - Updating attribute in the last row of a table with an Update Cursor
4599
02-29-2016 06:16 AM
TrilliumLevine1
Hello All,
I'm trying to update the value in a specific field ('uid_n') in the last row of a table with a value read out of a text file.  I've figured out how to return the last value in the table for the uid_n field, but am struggling with the actual update bit.  Does anyone have any ideas?  Any feedback is greatly appreciated!
My code so far:
import arcpy
from arcpy import env
import os
# open arcpar.txt
arcpar = open(r'C:\Users\admin\Desktop\ToeB 10.2\arcpar.txt')
# read UID line
line = arcpar.readlines()[1]
UID = line[4:-1]
# set workspace for arcpy
env.workspace = r'C:\Users\admin\Desktop\ToeB 10.2\Data Svenja\Toeb Svenja.gdb'
# possible feature classes
punkte = 'Punktobjekt'
# field to use to find last record in table
objectId = 'OBJECTID_1'
returnField = ["OBJECTID_1", "uid_n"]
sql_clause = (None,'ORDER BY {} DESC'.format(objectId))
last_row = ''
last_OID = ''
# function to copy text to clipbard
def addToClipBoard(text):
    command = 'echo ' + text.strip() + '| clip'
    os.system(command)
# call function to copy UID from arcpar.txt to clipboard
addToClipBoard(UID)
with arcpy.da.UpdateCursor(punkte, returnField, where_clause=None, sql_clause=sql_clause) as cursor:
    last_row = cursor.next()
    lastUID = last_row[1]
JoshuaBixby
MVP Esteemed Contributor
The error says 'row' is not defined because in Mitch's code there is no variable 'row', hence it is undefined when you try to update the cursor based on a non-existent variable.  I am not sure I completely understand what value you are trying to use to update the row with, but does the following work:
    last_row[1] = UID
    cursor.updateRow(last_row)
MitchHolley1
Have you tried updating the row with 'cursor.updateRow(row)'?
TrilliumLevine1
Hi Mitch, thanks for the quick feedback.  When I run that I get an error: 'row' is not defined.
JoshuaBixby
    last_row[1] = UID
TrilliumLevine1
Hi Joshua, yeah, that's exactly what I was looking for, I was missing the [1] in there.  Thanks!
