arcpy to edit *.sde files
4545
05-16-2016 10:58 AM
MichaelKnapp
Hi there -
Is it possible to, using arcpy, to edit the content of an *.sde connection file (or files) directly?
Based on some initial research, it seems this is not possible and that the closest I might be able to get would be to use CreateArcSDEConnectionFile_management to generate multiple new files at once.
Thanks.
NeilAyres
Once you have the original, you can make a connection to it.
env.workspace = "path and name of connection file . sde"
Then you can recover the properties of that connection file using Describe.
NeilAyres
What are your requirements to edit a connection file?
I think you are correct, you could read a connection file, create a new one, then overwrite the original.
MichaelKnapp
All that's needed is to swap out the server domain name in the *.sde files, but there are lots of *.sde files to update.
What would be the best arcpy function to use to read properties of the existing *.sde files?
Thanks so much for your quick reply.
NeilAyres
MichaelKnapp
Great, thanks again for all the information.
RebeccaStrauch__GISP
Hi Mike,
Kim at dec was asking the same question via email to me.  Haven't made contact yet.  Is thus related?  I mentioned you just asked the question here.
just FYI, for finding and updating other broken link, I had an addin Python addin for data inventory and “broken-link” repair.​   Not 100%, and haven't had time to keep working on it, but may help fix other issues in the future.
