Arcpy Sharepackage standalone script
2481
01-14-2023 05:42 AM
Rahul_Pandia
Hello,
I am not able to run Sharepackage tool from a standalone script.(unable to sign in to portal)
Basically, It is not able to connect to portal.Just to clarify I able to run this script as Model Builder.
Also I am able to connect to portal via arcgis pro.
Error:
Processing .... Share Package :
File "e:\script\test.py", line 130, in <module>
arcpy.management.SharePackage(in_package=Maps_vtpk, username=_username, password=_password, summary=_summary_shrPk, tags=_tags_shrPk, credits=_credits, public=_public, groups=[], organization=_organization, publish_web_layer=_publish_web_layer, portal_folder=_portal_folder)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 12777, in SharePackage
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 12774, in SharePackage
retval = convertArcObjectToPythonObject(gp.SharePackage_management(*gp_fixargs((in_package, username, password, summary, tags, credits, public, groups, organization, publish_web_layer, portal_folder), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 002119: Must be connected and signed into the portal.
Failed to execute (SharePackage).
Tags (3)
Rahul_Pandia
It turns out you need allow arcgis pro for offline usage
Then the Error vanishes
DanPatterson
MVP Esteemed Contributor
in pro or modelbuilder you are connected to portal if you signed in
002119: Must be connected and signed into the portal.—ArcGIS Pro | Documentation
is explicit, so if you need to sign in, then there are tools in arcpy to do so
SignInToPortal—ArcGIS Pro | Documentation
but not being a portal or enterprise person, you will have to experiment on your own
... sort of retired...
Rahul_Pandia
Yes... my understanding is in sync with yours
I had tried few combinations....but SignInToPortal has been disabled for standalone scripts(https://support.esri.com/en/technical-article/000021927)
but then there must be a way to call this tool
Rahul_Pandia
DanPatterson
As indicated previously "in pro or modelbuilder you are connected to portal if you signed in..."
