arcpy.SelectLayerByAttributes Where Clause
11646
14
11-15-2017 02:51 PM
JoeBorgione
In post earlier today, (Another da.SearchCursor Issue ) through an oversight on my part I couldn't execute a select layer by attributes function. Silly me....  At rate, I've moved past that issue but now faced with constructing a where clause that involves membership in a dictionary.
Essentially, I've constructed a dictionary of street types that looks something like this:
typeDict = {"AVE":1,"BLVD":2,"CIR":3}  #etc, etc‍‍‍
 As best as I can tell, the way to  see if a given string is a member of a dictionary, one can :
>>> typeDict
{'BLVD': 2, 'AVE': 1, 'CIR': 3}
>>> "AVE" in typeDict
True
>>> "ST" in typeDict
False
>>> "ST" not in typeDict
True
>>> if "somevalue" not in typeDict:
...     print "nope"
nope
Okay, easy enough. The problem is constructing a valid "where clause' for the SelectLayerByAttribute() when considering membership in a dictionary.  I've tried dozens of {}.format() approaches but the red font on my screen looks something like the U.S. spend deficit.  I need some advice to successfully select a record or records based on the dictionary:
intable = "C:\Path\To\File.gdb\Table
arcpy.MakeTableView_management(intable,"view")
fields = ["Type","StreetName"]
where = "StreetName >= 'A'    #just concerned with named streets, no numbers
with arcpy.da.SearchCursor("view",fields,where) as cursor:
    for row in cursor:
       Select = #need to format a where clause that
                # evalutes row[0] not in typeDict
       arcpy.SelectLayer,ByAttribute(view,"ADD_TO_SELECTION",Selection)
jamesfreddyc
bixb0012
Dan_Patterson
(I should just create a signature block with you guys in it; maybe I can convince my boss to put you on retainer....)
DanPatterson_Retired
Joe... for the back burner... but using Feature or Table to NumpyArray... even for one column, conversions can be quasi-vectorized easily, once you have a couple of steps.  Shown verbosely, but in essence, if you already have a dictionary of key/value pairs, they can be converted to an array, then the whole field can be queried by case rather than by row...  a small demo to give you ideas for the future.
# ---- Start with the beginning fluff of taking the data, making a temporary
#      storage array for output
#      Convert your dictionary... then run the 'for' loop which queries by case
#      rather than by row (this of course can be done all at once, but loops are
#      good for now
a = ['AVE', 'Not', 'BLVD', 'Nope', 'CIR', 'AVE', 'AVE', 'BLVD', 'CIR', 'nada']
a = np.array(a)
result = np.full(a.shape, -9, dtype='int32')
typeDict = {"AVE": 1, "BLVD": 2, "CIR": 3}  # ad nauseum
dt = [('Lookfor', '<U5'), ('ReplaceWith', '<i4')]
arr = np.array(list(typeDict.items()), dtype=dt)
ins = arr['Lookfor']
outs = arr['ReplaceWith']
frmt = """
Input data array
Temporary holding array
{}\n
Dictionary to array conversion
lookfor ..... {}
replace with. {}
print(frmt.format(a, result, arr, ins, outs))
for i in range(len(arr)):
    #result[np.where(a == arr['Lookfor'])[0]] = arr['ReplaceWith']
    result[np.where(a == ins[i])[0]] = outs[i]
frmt = """
magic done
In again, then out
print(frmt.format(a, result))
Then the results of the demo are
input data
['AVE' 'Not' 'BLVD' 'Nope' 'CIR' 'AVE' 'AVE' 'BLVD' 'CIR' 'nada']
output result
[-9 -9 -9 -9 -9 -9 -9 -9 -9 -9]
dictionary to array
[('AVE', 1) ('BLVD', 2) ('CIR', 3)]
lookfor ..... ['AVE' 'BLVD' 'CIR']
replace with. [1 2 3]
magic done
In again, then out
[ 1 -9  2 -9  3  1  1  2  3 -9]
# ---- you use arcpy.da.ExtendTable to attach the output result to the original
#      table...  Works best when your cases are obviously less than your records
I might have it now (I think)
Basically you want to check a street address to see if a street type occurs and if it does, you want to produce a new column which reclasses the street type.
Lets consider the following
    from_s = ['Road', 'Street','Lane', 'Court']
    to_s = [10, 20, 30, 40]
So in the above, if the address name contains any of the values in the 'from_s' you want to reclass that address to a new type for whatever purpose.
It isn't fully vectorized, but here is what I did in verbose form
# ---- Read in your street index and query fields shortcutting the searchcursor stuff
in_fc = r'C:\Your_spaceless\path_to_your\address.gdb\streets'
flds = ['OID@', 'Address_']
args = [in_fc, flds, None, None, False, (None, None)]
cur = arcpy.da.SearchCursor(*args)
a = cur._as_narray()
# ---- Establish your 'from' and 'to' classes
#      Make a temporary array for filling and ultimately joining
dt = [('IDs', '<i4'), ('Str_class', '<i4')]
out = np.zeros((len(a),), dtype=dt)
out['IDs'] = np.arange(1, 1001, dtype='int32')
# ---- Let's rock and roll
cnt = 0
for f in from_s:
    idx = np.array([i for i, item in enumerate(a['Address_'])
                    if f in item])
    out['Str_class'][idx] = to_s[cnt]
    cnt += 1
arcpy.da.ExtendTable(in_fc, 'OBJECTID', out, 'IDs')‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The reveal... Is this what you want to do?
I should point out that would be prudent to use a null value for an integer field this could be 'None' for text fields or another value for integer fields, for example on line 15.5 you could add
out['Str_class'].fill(-9)
JoeBorgione
Thanks Dan, but way more than I need. Boiled down to extreme basics:  I want to examine a table of records and determine if each record has a valid value in a given field.  Validity is confirmed by virtue of comparing the field value against a list.  If the record's field value is confirmed as valid, move on to the next record.  If the record's field value is confirmed as not valid, write that record to another table:  then move on to the next record in the original table for examination....
darn... so I guess you don't want to see my next incarnation... I will leave that to a blog
JoeBorgione
I'll read it there!
Thanks!
