arcpy script to compare two GDBs
2945
03-13-2019 10:56 PM
netflixdec
Consider two GDBs which as files such as FC, Table, Shape.
The script should be able to check and compare all the files in both the GDBs and if it finds a file with the same name it should further probe the file.
Assuming that the two gdb has an FC with same name XYZ, the script should now check and list the fields in the feature class.
same should happen with other files.
Tags (1)
DanPatterson_Retired
So you have looked at things like....
Table Compare—Data Management toolbox | ArcGIS Desktop
What else have you looked at?
Do you have a workflow that you have started?
Are you using modelbuilder or do you want to go straight to python?
netflixdec
Hello,
I am extremely new to both python and arcpy.
Yes, I have looked at this tool and have used it in a script individually. However, I am unable to get it all within one script.
So far I am using ListDatasets, ListFeatureClasses, ListFields for comparing the FC in the GDBs. But getting it to do tables and layers is daunting.
No, I am not using the model builder directly python
curtvprice
It sounds like you know what is required. What is your question?
netflixdec
I am not able to come up with it in a proper way.
netflixdec
Basically speaking i need a sample script for above task
