arcpy - saving results from a geometric network trace
5165
01-09-2016 02:30 AM
GregKing
I’m writing a script to perform some traces of a geometric network.  So far I have managed to create the script to setup all the layers and run the trace.  The result is the selection of the geometric network elements within a selection group.
The issue I am having is how to then save out the traced features into a separate feature class from the selection group.  Has anyone done this through python/arcpy previously and can provide some guidance?
Regards
Greg
KevinHibma
The output from Trace is actually a group layer. So you need to "select" the particular item out of the group layer you want before you can do something with it. In Modelbuilder, this is pretty straight forward as you'd use the Select tool (only available within Modelbuilder). With a script, you need to properly reference the layer inside the group that you want.
arcpy.Snap_edit(Flags, "'Primary OH Conductor' VERTEX '30 Meters'")
arcpy.TraceGeometricNetwork_management(El_Paso_Electric, "Storm_Net", Flags, "TRACE_UPSTREAM", "", "", "", "", "", "NO_TRACE_ENDS", "TRACE_INDETERMINATE_FLOW", "", "", "AS_IS", "", "", "", "AS_IS")
network = arcpy.mapping.Layer("Storm_Net")
if network.isGroupLayer:
    for sublayer in network:
        arcpy.AddMessage("  {} ".format(sublayer.name))
# Process: Select Data
#arcpy.SelectData_management("Storm_Net", "ServiceLocation")  # <--- dont use
# Build up the path to the item you want, in this case, "Storm_Net" is my output Trace, and "ServiceLocation" is the item inside I want.
arcpy.CopyFeatures_management("Storm_Net/ServiceLocation", outputFeatureClass)
FYI: Output from the AddMessage to list items in the GroupLayer:
  •   ElectricDataset_Net_Junctions
  •   MiscNetworkFeatureBank
  •   SwitchBank
  •   CapacitorBank
  •   FuseBank
  •   RegulatorBank
  •   Light
  •   Generator
  •   DynamicProtectiveDeviceBank
  •   Motor
  •   ServiceLocation
  •   TransformerBank
  •   Flags
  •   SecondaryUGLineSection
  •   SecondaryOHLineSection
  •   PrimaryOHLineSection
  •   PrimaryUGLineSection
DanPatterson_Retired
Did you try ... Copy Features
you may have to use MakeFeatureLayer first as per the trace help topic
Trace Geometric Network
ie
arcpy.CopyFeatures_management("your layer , "output filename including path")
KevinHibma
  •   SwitchBank
  •   CapacitorBank
  •   FuseBank
  •   RegulatorBank
  •   Light
  •   Generator
  •   Motor
  •   ServiceLocation
  •   TransformerBank
  •   Flags
jloiseaux
Hi, Thank you. I am running a weekly script to calculate fire hydrants coverage using Network Analyst.
From time to time the script was stuck on arcpy.SelectData_management("LayerA", "Lines").
  I ve just changed it to "LayerA/Lines" into a variable as you suggested in your post and now it does not get stuck anymore.  Thanks.
Greetings from France,
Have a great day.
Julien Loiseaux.
