arcpy - new line in geoprocessing dialog window
10249
18
04-14-2015 12:52 AM
MarkWisniewski
I am currently using;
arcpy.AddMessage(arcpy.GetMessages())
and
arcpy.AddMessage(fc)
to tell me the features that are being processed by the geoprocessing tool in my script. Is there a way to seperate these in the geoprocessing dialog window by a line spacing because it looks cluttered?
MarkWisniewski
The "Running script Clip..."is coming from arcpy.AddMessage(arcpy.GetMessages()) and not added by myself.
MarkWisniewski
This is a visual of what I am trying to achieve;
DanPatterson_Retired
as I said
arcpy.AddMessage("")
will produce a blank line
MarkWisniewski
No change
Did you try...as suggested...getting rid of the
arcpy.AddMessage(arcpy.GetMessages()) line?
All that line does is get all the messages ... if you want to see where the messages should be added...post your code
Then what happens when you remove that line? and just leave the arcpy.AddMessage lines alone.  Experiment until you understand the affect of both lines on the outputs.
MarkWisniewski
Sorry Dan, I can't get arcpy.AddMessage("") to do anything.
I can get arcpy.AddMessage(fc) to print shapefile names, but with no space before first shapefile.
last try and then this is going into my collection...
arcpy.AddMessage("\n")
otherwise post your code
MarkWisniewski
Its not going into your collection . That worked putting arcpy.AddMessage("\n") at the start of my script. Thanks for your patience Dan.
