ArcPy mapping - MapDocObject: Unable to save Attribute Error
5497
5
05-07-2013 08:08 PM
StephenPage
I???m running a script to update the SDE Connection file path. This works fine. But I???m getting an output error ??? SOMETIMES!
The error occurs at the Save Map statement:
File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\_mapping.py", line 828, in saveACopy
    self._arc_object.saveACopy(file_name)
AttributeError: MapDocObject: Unable to save. Check to make sure you have write access to the specified file and that there is enough space on the storage device to hold your document.
I have no Arcmap or ArcCat open.
Here???s my script:
import arcpy, os  # INPUT PARAMETERS Input_mxd = "G:\GIS\Weave\mxd\REBUILD\DataSrceTesting_2LblLayers_PptySbrbs.mxd" Output_mxd = "G:\GIS\Weave\mxd\REBUILD\newDataSource_EmptyOutput_3.mxd" Input_SDE = "Database Connections\Connection to vgeodb.sde" Output_SDE = "G:\GIS\Weave\Connections\Connection to 10.1.4.127.sde"  mxd = arcpy.mapping.MapDocument(Input_mxd) for lyr in arcpy.mapping.ListLayers (mxd):  mxd.findAndReplaceWorkspacePaths(Input_SDE, Output_SDE)  print lyr  print lyr.dataSource mxd.saveACopy(Output_mxd)
The print statements are just so I can see whats going on - the code appears to update the connection paths as required.
DuncanHornby
MVP Notable Contributor
The shutil error maybe occurring because you have not imported the module?  You would need to put it at the top of your script.
import shutil
But looking at your code I notice you have not put an "r" in front of your strings.
You want your code to look like:
Output_mxd = r"G:\GIS\Weave\mxd\REBUILD\newDataSource_EmptyOutput_3.mxd"
StephenPage
I (belatedly) found a thread "1. MapDocument.saveACopy() Error " from 5 May, which has some solutions in it.
I've tried these but can't get them  to work
i) the saveACopy statement still throws the "can't save" error
ii) the shutil.copy2(inputMxd, old_doc) statement says:
NameError: name 'shutil' is not defined
DuncanHornby
import shutil
StephenPage
Thanks for your reply which WAS appreciated very much (and solved my issue), and humble apologies for completely overlooking to respond!
Is perhaps putting an "r" in front of strings new to Arcpython under version 10? I don't recall this from 9.3, and it doesn't seem to be in my sample scripts from then.
Perhaps I need a refresher to update myself to the latest code!
Similarly, I haven't struck the 'shutil' module before, but my 9.3 copy methods don't seem to work. Couldn't get this to workk yet either - so I just manually copied the file - but I'll get back to that when there's time!
Thanks again
Steve
JamesCrandall
Steve,
From a quick look at some examples, the "r" in front of a quoted string indicates a string literal -- for example any escape characters will not be evaluated.  So,
print r'testing \n'
Would print the entire quoted string "testing \n"
print 'testing \n'
Would print "testing" and a newline space.
StephenPage
Thanks James
