arcpy.mapping.ListLayoutElements which element type to use?
1600
04-04-2013 08:39 AM
ChristopherOneal
I have a series of mxds that I have previously constructed which contain text elements and picture elements grouped. Their position within each mxd differs slightly. I would like to standardize the position of tese groups of text and objects/pictures. What element_type do I need to use?
markdenil
if you are after groups, use GRAPHIC_ELEMENT
DonIwanicka
You don't have to specify an element_type as the default is none. As long as your elements have names and you can identify their name and type with the element properties.
Don
KimOllivier
Honored Contributor
That is the catch with old MXD files.
The graphic elements did not have element tags for a name, so you have to go through by hand and give each one a name to use the new mapping module to edit them.
