ArcPy ListDataFrames on empty MXD crash
4072
13
05-29-2012 09:27 AM
AndrewLaux
I have a script that iterates through multiple directories and runs a report on mxd information. Running into problems with it however whenever an empty mxd is loaded.
Whenever running " DFList = arcpy.mapping.ListDataFrames(mxd)" I get a crash of the python script .
Is there any way to test for an empty mxd or perhaps some other problem that i'm missing here.
Andrew L.
RhettZufelt
MVP Notable Contributor
Hmmm, wonder if you open it with the new version, and select "Save a Copy" if it will keep broken paths in there and let you replace?
R_
David_JAnderson
No luck.  It crashed again.  Plus I learned that the arcpy.mapping.saveACopy methods also fails on this file.
For now it looks like I'll just have to screen out the older files for now and try open up a ESRI support ticket to see if they can resolve the problem.
RhettZufelt
I know this is about automating it, but if you right-click on the mxd in ArcCatalog and "change data source" does that crash also?
R_
David_JAnderson
No problem with doing that operation.
I now have an ESRI support ticket that I hope will resolve this problem.  Will post when I have results.
