arcpy in ArcGIS Pro - Setting a layer to have it own metadata
2157
02-08-2022 04:33 AM
HarshaPerera
Hello,
I am trying to use arcpy in ArcGIS Pro to set properties on layers including the description and summary. I am using
the metadata object to do this. The properties get saved. However, they are not used as the layer has not been set to
have it own metadata. How do I do this in arcpy? The current code is similar to the following
layerMetadata = layer.metadata
layerMetadata.description = description
layerMetadata.summary = summary
# The following do not have an effect
# layer.metadata = layerMetadata
# layerMetadata.save()
# This saves the metadata. However the layer is not set to use it
aprx.save()
Tags (3)
HarshaPerera
Thanks for the reply. Unfortunately, neither of those work. I found that getting and setting the layer definition does allow this to be changed.
e.g.
      l_cim = layer.getDefinition('V2')
      l_cim.useSourceMetadata = False
      layer.setDefinition(l_cim)
However, setting the definition (even if no changes have been made to the object) cause the layer to become disconnected. I'll raise a separate post for that.
DanPatterson
MVP Esteemed Contributor
Metadata—ArcGIS Pro | Documentation
synchronize? upgrade?
... sort of retired...
HarshaPerera
e.g.
Adrian
The hint using the CIM was great. Thank you very much! It works like a charm.
I'm currently working with ArcGIS Pro 3.4.5 and I don't have any problems with disconnected layers after changing the source metadata property.
