Arcpy For Loop to Apply Symbology to Multiple Layers
7242
10
03-14-2016 08:39 AM
DarrochKaye
I have multiple layers in ArcMap that I want to import a symbology for from a layer file. The code I have is as follows:
import arcpy
from arcpy import env
# Reference current MXD and dataframe.
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
layers = arcpy.mapping.ListLayers(mxd,"",df)
# Layer file symbology to be imported is in.
in_symbology_layer = arcpy.mapping.Layer("C:\LayerStyles\LayerFile.lyr")
# Layer to receive imported symbology.
in_layer = arcpy.mapping.ListLayers(mxd, "", df)[0]
# For loop to import symbology to all layers in current MXD.
for lyr in layers:
  try:
    arcpy.ApplySymbologyFromLayer_management(in_layer,in_symbology_layer)
  except:
    print "Failed to import symbology for: " +lyr.name
# Refreshes Table of Contents.
arcpy.RefreshTOC()
The code seems to work in parts, as the output I get is:
"Failed to import symbology for: Layer1
"Failed to import symbology for: Layer2
"Failed to import symbology for: Layer3..."
For loops are my Achilles Heel so any assistance would be greatly appreciated!
DK
Tags (3)
DanPatterson_Retired
you retrieve the first layer in the data frame and are trying to apply the symbology from layer on disk.  Have you confirmed that the layers are of the same type so that the symbology will apply?
("C:\LayerStyles\LayerFile.lyr")  should be (r"C:\LayerStyles\LayerFile.lyr")  raw formatted with the "r" just be sure it can find the layer.  So, dump the try except block so you get a real error message, confirm that the layer can be found and use a check to ensure that the symbology from that layer is appropriate for the layer it is trying to apply it to.
WesMiller
Change line 18 your using a list instead of  a layer
in_layer to lyr
ListLayers—Help | ArcGIS for Desktop
in_layer = arcpy.mapping.ListLayers(mxd, "", df)[0]       [0] should mean he is getting the first layer in the list... if that is not what he wants, then the question is muddier
WesMiller
Your right, I missed [0] on the end. So why the loop?
line 7... the current mxd... but I think there is more fundamental to just fixing up a for loop which contains a try except block which doesn't return any useful information in its current form.
DarrochKaye
My apologies if my original post was unclear. The code I posted was my attempt based on other pieces of code I know work.
I want to apply the symbology that is stored in a layer file to all layers I currently have open in ArcMap in a Group Layer. They are all polygon files and all have the same fields so there is no error in that regard.
DK
DarrochKaye
So far I have got the following code to work on a single, specified layer:
import arcpy
layers = arcpy.mapping.ListLayers(mxd)
in_symbology_layer = arcpy.mapping.Layer(r"C:\LayerStyles\LayerFile.lyr")
in_layer = arcpy.mapping.ListLayers(mxd, "09-03-2016 00_00_00", df)[0]
arcpy.RefreshTOC()
...but what I would like is to apply this code to multiple layers, e.g. layers in a Group Layer, rather than a uniquely specified layer, e.g. "09-03-2016 00_00_00".
DK
all_layers = arcpy.mapping.ListLayers(mxd, "09-03-2016 00_00_00", df)   # note ... no [0]
in_layer = all_layers[0]  # the first layer
for layer in all_layers:
    arcpy.ApplySymbologyFromLayer_management(layer, in_symbology_layer)  # guessing since arc-free
DarrochKaye
Solution:
import arcpy
# Layer file symbology to be imported.
all_layers = arcpy.mapping.ListLayers(mxd)
arcpy.RefreshTOC()
Thanks to all those who contributed.
DK
